Old 04-24-2008, 11:00 PM   #1 (permalink)
Club Region: SoCal
Reputation: endersgame is an unknown
Send a message via AIM to endersgame
idle gone wack
Sooo, sometimes after regular driving, my idle will jump to about 1500 after i stop somewhere to run an errand or what have you. It normally idles at 500. Then if ill stop somewhere else sometimes it just drops back to normal. What gives? Your responses are appriciated as always
Old 04-24-2008, 11:25 PM   #2 (permalink)
it could be lots of things,i would sy that your IAC (idle air control valve) is taking a crap
Old 04-25-2008, 12:39 AM   #3 (permalink)
Car: 04 WRX
Reputation: Strider327 is on thin ice
+1 Idle Air Control Valve Solenoid. Just take it off and give it a good cleaning and replace the gasket.
Old 04-25-2008, 03:04 AM   #4 (permalink)
Club Region: SoCal
hrmmmm right O. Thanks for the hlp guys
Old 04-25-2008, 10:23 AM   #5 (permalink)
b7g
b7g's Avatar
Reputation: b7g is an unknown
does this happen in traffic, high heat environment? Or just regular driving?
The reason i ask is because the cruise control appearantly starts pulling on the cable by itself when it overheats casuing high idle. I have that issue and will try to disconect the CC cable to check if the issue is still there.
drive = freedom
Old 04-25-2008, 05:44 PM   #6 (permalink)
SuBeast's Avatar
Club Region: NorCal
Reputation: SuBeast is on thin ice
i was going to say dirt MAF? but if it goes back to nromal, probably not.
Jetta VR - GIAC Powered
FAST
RELIABLE
CHEAP
Pick 2
Old 04-25-2008, 09:19 PM   #7 (permalink)
Club Region: SoCal
havent really driven her in traffic yet, and dont plan on it. heh. dont really live in a high temp environment. SD is great to me. Just happens with daily driving.
Old 04-26-2008, 03:52 PM   #8 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
+1 to cleaning the IAC and you should just as well clean out the MAF while your there you can hurt anything by doing that.
Old 04-27-2008, 08:06 AM   #9 (permalink)
b7g
b7g's Avatar
in addition, I loosened my cruise control cable and self-high-idle disappeared. I'll wait till warmer temperature to tripple check. Just FYI...
drive = freedom
Old 04-27-2008, 07:15 PM   #10 (permalink)
suddenthomas's Avatar
Reputation: suddenthomas is more helpful than not
Is your car totally stock? Do you have a bov?
Old 06-16-2008, 11:29 AM   #11 (permalink)
Car: 04 WRX
Reputation: Touge Daimao is an unknown
Send a message via AIM to Touge Daimao
damn...my idle is gettin' all weird too...only on hot days. I received a recall notice for a cruise control clip thingy, but have yet to make an appointment to get it done. Does this component contribute to the problem? Where do i loosen the cc cable?? Sorry for the noob response.
Old 06-16-2008, 03:38 PM   #12 (permalink)
the CC cable connects to the throttle body, if you look at it it has 2 cables , its the one on the passenger side. loosen the jam nut(I think its a 12 mm) and turn the bolt that the cable goes through until you have a little slack in the cable.
Old 06-29-2008, 05:19 PM   #13 (permalink)
Jag_Warrior's Avatar
Reputation: Jag_Warrior is an unknown
I began having this problem about a year ago (less than 40K miles), but only during the summer months. After I'd get off the interstate, my RPM's would go from 500-700 to 2000. This year it's gotten worse. The other day the RPM's went up to 3000+ at idle. Going through a drive-thru, I had to shut the engine off.
Idle Air Control Valve Solenoid, huh? I'm taking it in next week and I'll mention that before they go on their search and destroy (my wallet) mission.
Thanks much, guys!!!
Old 06-30-2008, 10:43 AM   #14 (permalink)
I would try the cruise control cable first.
Aarg matey!
ECU Pirated by RomRaider
