Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 05-09-2008, 01:50 PM   #1 (permalink)
Reputation: Nitram is an unknown
Exclamation I think I blew it?!
Hey guys looking for some help. Took my car out this morning and everything was fine till i got i to about 4000rpms, then it just took a dive like it wanted to stall. Runs great till it shud be making some boost then just takes another dive. Is my turbo blown? I didnt notice any smoke and my boost gauge is still working correctly.
Old 05-09-2008, 02:07 PM   #2 (permalink)
Longshot's Avatar
Car: 05 WRX
Could be a preturbo leak, we'll need your mods, if you've thrown a check engine light (and what it is). If your leaking it could cause the car to studder and/or stall out.
DTRacing Tuned
Old 05-09-2008, 02:18 PM   #3 (permalink)
Got a Hks hi-power catback, perrin intake, blitz boost controller. I did throw the CEL and it does studder.
Old 05-09-2008, 02:26 PM   #4 (permalink)
SuBeast's Avatar
Club Region: NorCal
Reputation: SuBeast is on thin ice
You say that it runs fine without boost so Maybe your boost controller is messing with the system???
Jetta VR - GIAC Powered
FAST
RELIABLE
CHEAP
Pick 2
Old 05-09-2008, 02:35 PM   #5 (permalink)
Yea it was when i had it out this morning, but i went out 10min ago and started it up and now its studdering, running like shit, and its even smelling weird.
Old 05-09-2008, 03:29 PM   #6 (permalink)
Longshot's Avatar
Car: 05 WRX
Check all the vacuum lines going to/from the controller and intake (pre and post MAF). Look for loose connections or tears.
DTRacing Tuned
Old 05-09-2008, 04:05 PM   #7 (permalink)
SuBeast's Avatar
Club Region: NorCal
Could be leaking out the intake before the MAF, because without the MAF hooked up, the engine studders and dies....
My guess is something wrong with the vacuum lines like Longshot mentioned, or boost controller is doing something... Most likely a leak somewhere, whether it's in the intake system or exhaust system i can't tell...
FAST
RELIABLE
CHEAP
Pick 2
Old 05-09-2008, 04:54 PM   #8 (permalink)
BC_Girl's Avatar
Car: 04 WRX
Reputation: BC_Girl is an unknown
Do you have a down pipe as well as the cat-back? And if so, does it have the wastegate?
Boys will be boys, but girls will be fast !
Old 05-09-2008, 05:31 PM   #9 (permalink)
Thanx Longshot n Subeast im gonna check it out now. I did have a dp but had to take it off to get it thru NJ inspection.
Old 05-09-2008, 07:13 PM   #10 (permalink)
Had a hose off the boost controller that was loose and nasty. I cut it and put it back on there nice and tight. Took her out and all seems swell. NO CEL! Thanx 4 all ## help fellas!
Old 05-10-2008, 09:55 PM   #11 (permalink)
SuBeast's Avatar
Club Region: NorCal
Nice! Glad to hear it's fixed
FAST
RELIABLE
CHEAP
Pick 2
Old 07-04-2008, 10:46 AM   #12 (permalink)
xmoniewrx's Avatar
Reputation: xmoniewrx is an unknown
I think a bann is in order for basebal2008 LOL!
[webpage] [posts] Reply With Quote
