### I Need Help - Subaru WRX Forum
post #1 of 4 Old 09-18-2009, 03:33 PM Thread Starter
Chris04WRX is an unknown
### I Need Help
wuts up guys i have a 2004 stage 2 wrx. my car isnt boosting AT ALL and is reading vacuum fine. my a/f is right where it needs to be and i have no idea whats goin on. the car seems to be driving fine until where my turbo should be spooling and im not getting anything at all. i checked my lines and ddnt see any immediate leeks or anything that stands out. i dnt think my turbo went just because i had a saab turbo go on me and when it went it didnt run at all n it blew black smoke everywhere, but i very well could be wrong. i would much appreciate any feed back on what might b wrong i could get from u guys. thanks in advance
Chris04WRX is offline
post #2 of 4 Old 09-18-2009, 04:35 PM
midniteblack's Avatar
midniteblack is more helpful than not
Send a message via AIM to midniteblack
so when you say it's making no boost it won't make anything over 0psi? Have you checked your couplers and y-pipe for your intercooler to make sure one is not seriously busted or loose? Maybe your wastegate is stuck open due to a broken spring? Check the wastegate shaft to see if there is any play in it or pull your downpipe off and check the wastegate flapper from there to make sure nothing broke on the flapper. Hopefully your turbo hasn't seized up!Notfunny!
midniteblack is offline
post #3 of 4 Old 09-18-2009, 06:33 PM
better pray to the gods of turbos that your turbo didnt seize..
post #4 of 4 Old 09-18-2009, 07:39 PM
04paulieWRX's Avatar
04paulieWRX is an unknown
make sure u have no leaks....did u recently change your blow off valve or intercooler?
04paulieWRX is offline
