I have a problem I need some insight - Subaru WRX Forum
post #1 of 15 Old 06-23-2009, 03:40 PM Thread Starter
The New Kid is an unknown
My wrx broke down on me saturday toke it 2 a shop and mechanic is telling that its my computer (ecu I guess he means) idk and he's is telling that because I put my exhaust system on and that it fried my computer how tru is that I don't understan how that works but idk can some one explain thanx a lot
The New Kid is offline
post #2 of 15 Old 06-23-2009, 04:13 PM
huh?
Exhaust systems don't fry ecus. Can you be any more specific about the symptoms you're experiencing? "My wrx broke down" isn't really the best description for us to go by. Is the car not starting? Does it start but run rough? Also, a complete list of the exact modifications on your car would also be helpful. Without that information, I think we'd all just be taking stabs in the dark trying to help you get your car back up and running.
post #3 of 15 Old 06-23-2009, 04:20 PM
Also, if you have a CEL get the code read and post it on here for us to better help you.
post #4 of 15 Old 06-23-2009, 04:42 PM Thread Starter
ok well it only has turbo back exhaust only mod
I was drivin and started getting like knocking or it also sounded like air was coming out of some where but it was still runnin so I figured I can get it home I pull 2 a light shift into neutral and it cutt off completly it rolled into a gas station it started then I tryied pullin out it was real rough and then it cut off again started one more time now it does not start
That's ### I was thinkin when does an exhaust mess up the ecu I a cel its o2 sensor because of the new exhaust any thing else let me know
Thanks so much
post #5 of 15 Old 06-23-2009, 05:43 PM
Air coming out of where? I mean i know you were driving, but a general area would also help.
post #6 of 15 Old 06-23-2009, 07:52 PM
07VTRex's Avatar
07VTRex is an unknown
if your only mods are turboback exhaust and you are hearing a lot of air then it sounds to me like you have got an exhaust leak somewhere...
I have had dozens of exhaust leaks before but none of them ever made my car run like garbage.
Did you use new gaskets when you put on the exhaust?
Maybe if the leak is where the downpipe connects to the turbo its causing enough turbulance to mess it up???
If you have a CEL get it checked for free at autozone or something. If you are too lazy for that you could just disconnect your battery to reset the ecu, then see if it fixes the prob or the CEL comes back on....
07VTRex is offline
post #7 of 15 Old 06-23-2009, 08:23 PM Thread Starter
Its came from the engine bay I don't think its a exhaust leak I put new gaskets n I don't think that would prevent my car from starting correct me if I am wrong ..it could have not been air but it was knocking it would go away and then come back.. The car does not start so idk how I would get it to autzone .. My had gone off timing about 2 months ago and the valves were bent It fixed by this mechanic and it has been a month since I got the car back I thinkin he did something wrong is tryin 2 cover him self some one told me that it could be the tie rod is coming loose or came loose
post #8 of 15 Old 06-23-2009, 08:31 PM
07VTRex's Avatar
again, another stab in the dark, BUT since you have a pre-06 WRX meaning that your uppipe has a cat in it. THe turboback may be responsible for the sound of air because when you free up the exhaust flow you can HEAR the turbo moving air, which could be what you are hearing.
Following that theory the extra suction caused by the freed up exhaust may have caused the cat in your uppipe to shoot into your turbo...
07VTRex is offline
post #9 of 15 Old 06-23-2009, 10:19 PM
It is a possibility the cat on the uppipe took a dump but the way you described your car sounds to me like your car is really hurt.
Besides getting the code read, if you have one......is to get a compression check...especially since you just recently had some internal engine work.
post #10 of 15 Old 06-24-2009, 07:09 PM
Try listing all your mods....................................
dumdum is offline
post #11 of 15 Old 06-24-2009, 11:14 PM
03 CrazyTaxi's Avatar
Did you pull the intercooler off when you did the exhaust install? If you did, you may not have the piping connected completely. That would cause a massive boost leak which sounds like air rushing AND will cause it to run like crap.
Also, get some form of engine management. That will take care of the CEL and get the most power out of the modifications.
03 CrazyTaxi is offline
post #12 of 15 Old 06-25-2009, 01:32 AM
jed344's Avatar
jed344 is an unknown
i agree with crazytaxi when i put my new TMIC forgot to tighten one of of the connection and made it sound like i had a EWG on my first test run
jed344 is offline
post #13 of 15 Old 06-26-2009, 12:53 AM Thread Starter
Ok one of the mechanics said I need a ecu reflash would getting the cobb assport do it for me? If not what is a good ecu I should get
post #14 of 15 Old 06-26-2009, 11:27 AM
You dont need an ECU, you need some type of Engine Management. Depends on your tuner and your own capbility. I love my AP, but some also swear by opesource tuning (tatrix cable and romraider), there is also the Utec, and stand alone units.
post #15 of 15 Old 06-26-2009, 08:14 PM
UTEC has kinda fallen behind compared to AP and OpenSource. I'd recommend OpenSource if you want to save money. It's the cheaper of the two since there is no hardware to buy. You just reflash your stock ECU with a laptop and a USB to OBDII cable.
