How to check MAF - Subaru WRX Forum
post #1 of 11 Old 03-22-2008, 10:18 PM Thread Starter
VD5505's Avatar
How to check MAF
i think my MAF sensor is going bad because i can hardly give it any gas and my car bucks so bad but if i hardly press down on the gas it will kinda run, i cleaned the MAF and it still doesnt run any better but does anyone know how to check the MAF like the out put of it or anything with my volt meter thanks alot
VD5505 is offline
post #2 of 11 Old 03-23-2008, 01:11 AM
"sub"erman is an unknown
Sounds like you might have a throttle position sensor problem too. But to answer your question, you can probably pull a wiring diagram online that will tell you which wire is which, or you can just start probing with your volt meter and you'll find them. You'll have a 12v power supply, a ground, a 5v signal return wire which goes back to the ECU. With the car on you should be able to read a voltage on the reference wire. Play with the throttle a little to see what the voltage does because it will vary with the amount of air flowing through it. If the voltage doesn't move or goes out of range you're gonna want to replace the sensor. If things appear to be within range check for a bad TPS.
Also, have you done any work under the hood lately? Possible vacuum leak from bumping the hoses.
"sub"erman is offline
post #3 of 11 Old 03-23-2008, 01:14 AM Thread Starter
VD5505's Avatar
well i cleaned my MAF really good and put new plugs in it and when i go to barly get on it, it will jerk and stuff and i can not rev past 4 grand and it is running really really rich, do you think my computer went out???? i will try the TPS tomorrow
VD5505 is offline
post #4 of 11 Old 03-23-2008, 01:15 AM Thread Starter
VD5505's Avatar
oh yea and my CEL lights are a P0301, PO302, PO303, AND PO304
VD5505 is offline
post #5 of 11 Old 03-23-2008, 01:32 AM
Wow, those are misfire codes for all four cylinders. You're not going to find the problem in the MAF or TPS if that's what's coming up. Are you running any kind of EM? What mods do you have?
post #6 of 11 Old 03-23-2008, 09:44 AM
might be bad coil packs. check to see that their not loose. and try resetting the ecu
post #7 of 11 Old 03-23-2008, 10:37 AM
Did you put the plugs on the coil packs right? the black plug goes on the rear coilpacks and the white plugs into the front ones.
nagyhead is offline
post #8 of 11 Old 03-23-2008, 10:53 AM Thread Starter
VD5505's Avatar
Yea all that is fine i was driving down the Highway and it was running fine then all of a sudden it felt like i hit a wall and wouldnt drive it would just jerk back and forth like no other but if i hardly touched the gas i could drive it, now it wont rev up past 4 grand and right once i get it into boost just like 1 psi it will go way rich like 10.1 and fall on its face, i was heading home from getting a pro tune as well i have a Cobb, and i have had that cobb on there for over a year, thanks for all your help guys
VD5505 is offline
post #9 of 11 Old 03-23-2008, 11:21 AM
then whoever did the tune messed something up.
post #10 of 11 Old 03-23-2008, 11:38 AM
Hell yeah take it back to whoever tuned your car, shit If this happened to me, i would have turned around as soon as the bucking happened.
nagyhead is offline
post #11 of 11 Old 03-23-2008, 11:54 AM Thread Starter
VD5505's Avatar
It happened four hours after my tune driving home from chicago to des moines and when I switch back to my other fuel map it still runs the same. Do you think it could be my computer.
VD5505 is offline
