hissing noise - Subaru WRX Forum
post #1 of 8 Old 03-16-2008, 02:05 PM Thread Starter
notoriousKID is an unknown
hissing noise
i have a 04 wrx with a vf39 turbo and just last night the turbo started to sound a little weird, now it sounds like it is building up boost but isnt letting it out and making like a hissing noise or sounds it like theres a leak or something, it still makes a little boost but you cant shift over like 4k
notoriousKID is offline
post #2 of 8 Old 03-16-2008, 02:13 PM
BC_Girl's Avatar
BC_Girl is an unknown
Check out Turbo Whine + Valves ticking in this forum, it may be a similar problem.
Sorry: don't know how to post the link like everyone else does
BC_Girl is offline
post #3 of 8 Old 03-16-2008, 02:21 PM
Black05WRX's Avatar
Black05WRX is an unknown
Honestly, it sounds like a leak issue, on my DSM that happen, but it was two things, one my ecu was losen power from a bad ground so I had to kick it to make it drive again, or you have a boost leak issue some where.
Black05WRX is offline
post #4 of 8 Old 03-16-2008, 03:16 PM
do u have an aftermarket bov? check that also. what other mods do u have to your wrx?
post #5 of 8 Old 03-16-2008, 08:02 PM
Sounds like a leak, check I/C connections, lines to/from BOV/BPV. List of other mods would also maybe help.
post #6 of 8 Old 03-17-2008, 07:31 PM Thread Starter
yea its got a forge bov, it has a 3" turbo back exhaust with uppipe and downpipe sti pinks aem intake with perrin turbo inlet house greddy boost controller...
post #7 of 8 Old 03-17-2008, 11:03 PM
No Em? I would check all the hoses like mentioned, and start with the Turbo inlet an work you way to the throttle body. Could be a uppipe leak as well. Look for carbon building up around the Exhaust connections.
nagyhead is offline
post #8 of 8 Old 03-18-2008, 03:22 PM
darthsofearu is an unknown
it may also be the waste gate actuator causing the boost problem. the hissing sounds like a boost leak but i cant tell for sure without hearing it myself. also, your bov may just be opening prematurely. good luck
darthsofearu is offline
