high speed vibration - Subaru WRX Forum
post #1 of 12 Old 01-19-2010, 12:23 PM Thread Starter
HOCKEYSCOOB2 is an unknown
Exclamation high speed vibration
i have a 2002 wrx sedan with a hks DP, greddy evo2 tbe, no tune.
i was driving today and at about 75 80 mph i started to get an viberation in my car.
it got worse as i went faster, it got so bad i could see my hood wobbleing and couldent get to 100 mph before it felt like my car was going to shake it's self apart.
my lugs are good, but i know my front CV boots are both broken.
has anyone herd of this kind of problem?
HOCKEYSCOOB2 is offline
post #2 of 12 Old 01-19-2010, 01:49 PM
mfarnham's Avatar
mfarnham is an unknown
Sounds like your wheels are unbalanced.
mfarnham is offline
post #3 of 12 Old 01-19-2010, 02:21 PM
You probably just need to clean your wheels and/or get them balanced.
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #4 of 12 Old 01-19-2010, 02:29 PM Thread Starter
my tires are balanced, i checked them last week at NTB.
post #5 of 12 Old 01-19-2010, 04:54 PM
mfarnham's Avatar
Just to be sure, I would definitely clean your wheels, and check for any dirt or other junk in the wheels.
mfarnham is offline
post #6 of 12 Old 01-19-2010, 06:45 PM
gaz123 is an unknown
my 03 rex does that when it snows, it took me a while to figure out, i had ice frozen to the inside of my wheel, i hear warped discs can have this effect aswell
gaz123 is offline
post #7 of 12 Old 01-20-2010, 08:44 AM
tknuuttune is an unknown
I think your profile said you're in Texas, so you wouldn't have the snow in your wheel problems that we have up here in New England.
It could be a band seperation in one of your tires, I had that in one of my cars, and as I drove faster, the more vibration I got. Do you feel it more in your hands/steering wheel (front tire problem) or more in the seat of your pants/seat (rear tire problem)?
tknuuttune is offline
post #8 of 12 Old 01-20-2010, 10:52 AM Thread Starter
i can feel it in the floor and pedals.
post #9 of 12 Old 01-20-2010, 11:03 AM
My guess would be the rear, but try rotating your tires and see if the vibrating, and where you feel it changes. If there are no changes, chances are it's something else, if there are changes, its tire related.
post #10 of 12 Old 01-20-2010, 10:01 PM Thread Starter
ok i'll try to rotate by monday, i will see if anything changes.
post #11 of 12 Old 01-21-2010, 08:50 PM
ducnial is an unknown
Tires, check 'em again. Some times the sticky wheel weights come off. Should be able to isolate which wheel by feel. Sounds like front - left or right?
ducnial is offline
post #12 of 12 Old 03-26-2010, 12:23 PM
laup is an unknown
I have a very similar problem on my stock 06 WRX. I had the front tires replaced and it improved but didn't go away. I think I feel wobble around 30 mph and 65 mph which is just weird. There is no wobble when I break so it can't be the rotors, right? Any luck with your car?
laup is offline
