High Rpms at Idle but no CEL - Subaru WRX Forum
post #1 of 13 Old 11-27-2011, 05:29 PM Thread Starter
WRXInfantryGuy's Avatar
WRXInfantryGuy is an unknown
Please give me some info
TJ Butler
WRXInfantryGuy is offline
post #2 of 13 Old 11-27-2011, 05:38 PM
Well give me some info to go on????
post #3 of 13 Old 11-27-2011, 06:06 PM
mazzanic's Avatar
mazzanic is an unknown
^^ high rpms at idle looks like he was sayin
mazzanic is offline
post #4 of 13 Old 11-27-2011, 06:29 PM
I have no idea what might be done to his car? Did he recently change something on it, did it just start doing it all of a sudden, did he just fill up with gas? These are things that help out when solving issues like this.
post #5 of 13 Old 11-27-2011, 07:20 PM
mazzanic's Avatar
Guess dude doesnt care that much. When i had problem i had my iphone on auto refresh hopin someone would post
mazzanic is offline
post #6 of 13 Old 11-27-2011, 08:51 PM
cwinterbower is more helpful than not
Probably a vacuum leak, but like was stated above, hard to help much when such a generic symptom can have many causes.
cwinterbower is offline
post #7 of 13 Old 11-27-2011, 08:52 PM
ejs0806 is more helpful than not
is it happeneing when cold starting?? lol
ejs0806 is offline
post #8 of 13 Old 12-01-2011, 03:52 PM Thread Starter
sorry i was out of town no computer around i had the engine block replaced and it ran fine for a few days then it started happening the rpms are at 2k while idling
TJ Butler
post #9 of 13 Old 12-01-2011, 04:40 PM
Still a barrage of causes for this sort of symptom. If someone was in your engine bay chances are you have a vacuum leak somewhere.
post #10 of 13 Old 12-02-2011, 08:13 AM
Does it ever get to normal RPM? Check the throttle cable.
post #11 of 13 Old 12-02-2011, 05:29 PM Thread Starter
ya the rpms do go back down after i drive it for a while. i do know that one of the intercooler hoses is cracked but i have new ones on order could this be a cause??
TJ Butler
post #12 of 13 Old 12-02-2011, 07:10 PM
That would be a vacuum leak. How big is the crack? I would be pretty easy on it, in fact if it was mine I wouldn't drive it if it was a decent sized crack, probably running crazy rich on boost and lean on off throttle.
post #13 of 13 Old 12-03-2011, 08:41 AM
BoostinChick is a helpful contributing member
On my DSM, this usually also happens if I forget to put back one of the ground wires to the chassis. You mentioned the engine block was replaced, you sure everything was hooked back up? From rebuilding my transmission, I know there is a ground right around the pitch stop and another (for the starter) that goes to on one of the bolts to the transmission.
Get that vacuum leak fixed first and do the test to make sure there are no others. I would guess either a ground/electrical issue or a leak.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
