Help: Losing Boost - Subaru WRX Forum
post #1 of 6 Old 02-24-2006, 01:03 PM Thread Starter
Help: Losing Boost
It seems after 5000 rpms, my boost drops from .8 or .9 to .6 or .5 - and I notice a loss of power from 5000 to 7000 rpms. If anybody could tell me what to do or what to look for, I'd appreciate it. Thanks.
2002 WRX is offline
post #2 of 6 Old 02-24-2006, 06:25 PM
WRXtreme's Avatar
I am pretty sure that the ECU lowers the boost once you get into the higher RPMs.
WRXtreme is offline
post #3 of 6 Old 03-31-2006, 11:11 AM
The stock turbo is not big enough to keep full boost all the way to red line. It tapers off as the rpms go up.
DougKmcse is offline
post #4 of 6 Old 04-03-2006, 03:35 AM
joker97's Avatar
as above
joker97 is offline
post #5 of 6 Old 04-03-2006, 03:36 AM
joker97's Avatar
change to bigger turbo if you want to improve on this otherwise it's normal
joker97 is offline
post #6 of 6 Old 04-03-2006, 07:19 PM
nick4592's Avatar
true true...but you could always tighten the wastegate...it'll hold a bit better then...but only tighten it a little....and 'test boost' it after every 1/4 turn or so
nick4592 is offline
