Please somebody help me im loosing boost really bad in the higher rpm's, I thought it was my bov, i checked everything's good and tight i even lubed the bov piston still the same any sugestion's would be apreciated.... thanks
How much are you losing? It's normal to spike the boost then it will settle down again.
If you are going just by the feel of the car, then after 6500RPM the car doesn't accelerate as fast in my opinion.
*Clears Throat* I agree with you that the UTEC is not God, for that matter no Engine Management is. Why do ecutek when you can go with AccessECU for practically half the price, with the only cost difference being one was built and designed "in-house".
ECU reflash-management is the way to go, would have been a better way to put it.
I'd try to put the stock valve back on and see what happens. I couldn't tell if i was just getting used to the car or if it was just slower so I datalogged the car and found that my rfl valve was leaking almost 2psi after 5500rpm compared to the stock valve even with 6 washers in it.
