Old 05-26-2008, 01:35 AM   #1 (permalink)
Boober909's Avatar
Reputation: Boober909 is an unknown
help i'm so screwed!
so my 02 wrx was acting weird, in 1,2,3 it was going decently, no problems, but when in 4th or 5th, when starting at like 2-3000 rpms, if i punched it, it would slowly raise to about 4000 rpms, then jump to 7 very quickly, then drop back down and climb up normally, i thought this was jsut my clutch and my dad agreed, so i took it in to my friend and he said the clutch is perfectly fine, my turbo is screwed up and not picking up boost properly and i need to take it to the dealership. the problem, the dealer here charges 120 an hour labour fees and that will rape me hardcore. so i'm wondering what you guys think is causing this, it doesnt seem to me to be the turbo, or it wuold do it in all 5 gears i would think, so is it maybe the cpu is screwed up? right now i have 3 inch uppipe and 3 inch turbo back exhaust. the cel light is on because i didnt do the lower cel fix, but i don't think that really matters does it?
please help! thanks,
Old 05-26-2008, 01:41 AM   #2 (permalink)
Gucci Maine's Avatar
Reputation: Gucci Maine is on thin ice
lights in your dash display come on for a reason to let you know what is going on with your engine you should prob. pay attention to em and act accordingly. plug up to a computer and check the codes, maybe its a vacuum leak?
Old 05-26-2008, 01:44 AM   #3 (permalink)
Boober909's Avatar
yeah dude i got them to check the code when i took it in it's just the 02 warning indicator. it goes on and off.
Old 05-26-2008, 12:58 PM   #4 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
OK, how does your friend know that your clutch is fine?? and a turbo that is going bad is not going to make your car rev up to 7 grand and have you car just sit there, how you explained it to us it sounds like the engine is reving up but its not putting the power to the drive train= bad clutch, another thing i can come up with is that sometimes when a clutch is starting to go out that in a lower gear you might not feel the slip as bad as when you put it in a higher gear it will have to work harder to get going so it will slip, take the dust cover off your tranny there are two 10mm bolts holding it on and see if you see any cluctch material.
Old 05-26-2008, 06:36 PM   #5 (permalink)
+1 to VD5505
Old 05-26-2008, 09:44 PM   #6 (permalink)
Boober909's Avatar
because he works at midas and he had the journeyman mechanic look at it and they said the clutch is fine.. so i have no idea. i'll try taking the dust cover off, where is it located. on the side of the tranny?
Old 05-26-2008, 09:53 PM   #7 (permalink)
Reputation: awdturb is an unknown
really sounds clutch...tell him to double check
Old 05-26-2008, 09:55 PM   #8 (permalink)
Boober909's Avatar
yeah maybe i'll just take it to a different mechanic shop and see what they say. if it was turbo you'd think it would be like all boost all the time right?
Old 05-27-2008, 12:03 AM   #9 (permalink)
Actually it would more likely be no boost none of the time.
Old 05-27-2008, 02:11 AM   #10 (permalink)
Boober909's Avatar
hehe yeah. so i picked it up tonight, i guess the mechanic is a dick and told the owner that it's the turbo because he didnt want to do the clutch on the car since it's a huge job.. so he made my friend tell me on the phone while the boss was listening that it wasnt the clutch.. so yeah i'm going to take it somewhere else.
Old 05-27-2008, 02:21 AM   #11 (permalink)
VD5505's Avatar
thats screwed up man, if i worked in a garage and knew that a job was a big job and your getting paid for it, wouldnt you want to do it???? but there are some really good DIY threads on here on how to pull your tranny and change your clutch i have done it twice and its not that bad man, i would stay with the stock clutch as well just buy the stock replacement Exedy clutch i buy them for $200 bucks shipped clutch pressure plate and throw out bearing.
Old 05-27-2008, 10:28 AM   #12 (permalink)
it's your clutch...taking the transmission out of a wrx is easy, 2 hrs max.
Old 05-27-2008, 08:25 PM   #13 (permalink)
Boober909's Avatar
don't you have to pull the whole engine out? can you link me to this clutch maybe i'll just do that a guy quoted me 1700 today
Old 05-27-2008, 08:40 PM   #14 (permalink)
Boober909's Avatar
and what about the flywheel should it definately be replaced or just resurfaced or what?
Old 05-27-2008, 09:31 PM   #15 (permalink)
VD5505's Avatar
dang man i will fly out there and do it for you for 1500, trust me you can do this yourself with some tools and jack stands and a day off, there are some DIY on here, i took alot of pics when i took mine out i was going to make a really good DIY maybe i should work on that now lol
