Help, help, 2002 wrx does not start, does not make any noise, clock does not work - Subaru WRX Forum
post #1 of 1 Old 02-18-2010, 12:59 PM Thread Starter
babakrad is an unknown
All
recently bought a 2002 WRX, one day i turn the switch and nothing happened. few minute later, the car start. 4 days ago and in the morning, i turn the switch and nothing happened, since then, the starter dont make any noise or turn. battery is good, starter is good, starter has power, selonoid does not. i can not figure out why the power does not get to the selonoid. track the wire and it goes through the firewall, i can not track it from inside. does any body now if there is any relay or fuses associated with the selonoid? i check all the fuses in and outside in the engine compartment and they are all good. i also checked the clutch switches and they were fine (never checked the neutral gear switch). i push the car and starts in first gear with no problem.
second
my clock does not work. are these known to die fast?
babakrad is offline
