help god speed radiator with no cap - Subaru WRX Forum
post #1 of 3 Old 06-10-2009, 01:37 PM Thread Starter
nj kiter's Avatar
so i went to change out my radiator no the 2004 sti, when i realized that it has no cap to it. am i missing something here. i am confused as to what is going on with this. so is their suppose be no cap. or is it just like that
Photobucket
Photobucket
nj kiter is offline
post #2 of 3 Old 06-10-2009, 04:00 PM
thats a radiator for an 02 WRX...they dont have a radiator cap just the coolant tank on the intake manifold...I think it should still work though if you fill it using the tank on the manifold
post #3 of 3 Old 06-10-2009, 05:45 PM
03 CrazyTaxi's Avatar
I'd send it back and get the right one. The stock system is designed with 2 caps and 2 vent tubes to the resevoir. The bugeyes only have one vent since there is only the cap on the resevoir attached to the manifold. You'll end up leaking coolant once it gets warm unless you plug the second line. Won't be much but over time it will be noticable.
03 CrazyTaxi is offline
