Help, Gc8 Boost Issue - Subaru WRX Forum
post #1 of 1 Old 04-02-2013, 06:30 AM Thread Starter
Having problems with running stock boost (14psi) on my MY00 GC8 WRX. At the moment it only runs 8-9psi.
Current setup:
- APS dual entry tmic
- vf30
- 3? APS tbe with hi-tech muffler
Have checked and done the following:
- tmic piping.
- Switching the stock bpv with another stock bpv.
- Tried a manual boost controller on full setting and only runs 12psi (which shouldn?t be the case if it?s totally dialled all the way).
- Bypassing the solenoid by blocking off the hose and hitting fuel cut. Got more power but still didn?t seem right.
- Resetting the ECU.
- No significant sound in the cabin coming from the engine bay when driving which would indicate a boost leak.
- Had the problem when I bought it stock with the td04 and stock tmic, so I don?t think it would be the tmic or vf30 installed in the car currently. I didn?t realise I was running 8-9psi until a friend tested it through an OBD meter.
- Restrictor pill is in its correct position.
Have taken it to a few forum members and still trying to find an answer. Am really stumped for ideas apart from taking it to a place which does pressure testing. Anyone with some ideas or similar problems please let me know.
See pictures below (note: I have circled in red a pipe T-section which I'm not sure why it doesn't have a hose connecting to it, when I put my finger up against it and lift up the accelerator line I feel it sucking my finger in a little bit)
http://img21.imageshack.us/img21/6031/engine1y.jpg
http://img844.imageshack.us/img844/681/engine2c.jpg
http://img201.imageshack.us/img201/6549/engine3d.jpg
http://img687.imageshack.us/img687/778/engine4b.jpg
http://img171.imageshack.us/img171/4066/engine5.jpg
http://img145.imageshack.us/img145/4714/engine6.jpg
d.lo is offline
