Help fixing POO31&37 - Subaru WRX Forum
 4Likes
post #1 of 17 Old 01-04-2014, 12:44 PM Thread Starter
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
Both code are popping up after I warmed my car up this morning, How to fix these code? What could have caused this? Should I just go get protuned?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #2 of 17 Old 01-04-2014, 01:08 PM
boo-key's Avatar
check all your fuses and the wiring on and going to your o2 sensors.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 17 Old 01-04-2014, 01:38 PM
Brockton's Avatar
Look for the fuse labeled ALT + B
Brockton is offline
post #4 of 17 Old 01-04-2014, 01:40 PM
boo-key's Avatar
If there's no fuses blown or damaged wiring, I would unplug your sensors, turn key on, and check pins on harness with a multimeter. One of the wires should be a heater wire and have voltage. If you have correct voltage its probably your sensor. If you don't then its a electrical problem.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #5 of 17 Old 01-04-2014, 03:05 PM
POO...don't you pick that up with a pooper scooper?
turmic and arewmors like this.
post #6 of 17 Old 01-04-2014, 04:43 PM Thread Starter
Premium Member
Nathan21's Avatar
No blown fuses, no damaged wires, do you know what the volts r suppose to be?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #7 of 17 Old 01-04-2014, 04:50 PM
boo-key's Avatar
That, I don't. Ill take a look and see if I can find out when I get a chance. most likely if it was something electrical you will not be getting any voltage at all.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #8 of 17 Old 01-04-2014, 04:52 PM Thread Starter
Premium Member
Nathan21's Avatar
I know when I check them on like civics it will show voltage just a different then what is should be but still shows something
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #9 of 17 Old 01-04-2014, 05:33 PM
boo-key's Avatar
I found the diagnostic procedure for those 2 codes in my service manual. Now I just gotta figure out how to get it from my computer to here. Im computer challenged.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #10 of 17 Old 01-04-2014, 06:36 PM
So the rear o2 wiring isn't hitting up against the driveshaft?
post #11 of 17 Old 01-07-2014, 10:51 AM Thread Starter
Premium Member
Nathan21's Avatar
Sorry on the late replay Paul, but no it isn't, I finally got my multimete last night back and did all my testing, it is the sensor so I ordered my downstream sensor now I just have to find the upstream sensor
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #12 of 17 Old 01-07-2014, 12:53 PM
boo-key's Avatar
Did you get the troubleshooting section from the service manual that I emailed you?
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #13 of 17 Old 01-07-2014, 12:55 PM Thread Starter
Premium Member
Nathan21's Avatar
Yep! gotta thank you a lot on that Adair!
Really made my life a lot more easy!!!
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #14 of 17 Old 01-14-2014, 11:10 AM Thread Starter
Premium Member
Nathan21's Avatar
So guys, I changed all the sensors, checked all the wiring and still have the codes.
Talked to tuner and they said they are for sure it is a wiring issue.
Will be bringing my car into a local shop and have them try and fix it for me, I have given up hope doing it myself
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #15 of 17 Old 01-14-2014, 12:34 PM
Did you ever think the Fiat dealership screwed it up when they changed the engine?
LW_Black4 likes this.
