help with electronic prosport boost gauge... - Subaru WRX Forum
post #1 of 7 Old 01-06-2008, 08:38 PM Thread Starter
Registered User
wrecker83's Avatar
wrecker83 is an unknown
Ive installed this electronic boost gauge, and have had it for about a month now. its worked fine, up until just last night when i installed my catless downpipe and was performing a test drive. there should be no relation between my boost gauge failing on me, and my install, but im at a loss, and dont know where to start.
-The gauge is completing its normal opening ceremony, and then it just sits at negative whatever.
-when i rev, nothing happens, and when im driving nothing happens.
-Ive checked the electronic boost receiver, and when i unplug it, the boost gauge slowly moves to max boost, and then when i plug the receiver back in, goes back to negative whatever.
-i dont know what would cause my boost gauge to not register how much boost im getting.
any help would be GREATLY appreciated.
-b-
wrecker83 is offline
post #2 of 7 Old 01-06-2008, 08:56 PM
b7g
b7g's Avatar
b7g is an unknown
Is there a recet button or a knob on the gauge itself? Plus check the wires of the receiver for disconnected or corroded connection. I have an electric boost gauge( Omori), the only thing i can think of is a ground or other wire dissconnected...
Maybe someone can shed more light on the issue, but this seems like a problem with a receiver/sender.
drive = freedom
b7g is offline
post #3 of 7 Old 01-06-2008, 09:11 PM
the sender probally went out, call prosport, they will send you a new one for free
nagyhead is offline
post #4 of 7 Old 01-06-2008, 09:50 PM Thread Starter
Registered User
wrecker83's Avatar
yea, my first thought was the sender. the gauge itself is receiving power, just not getting a reading on the boost pressure. thanks for the insight. and im glad that prosport will hook up a brand new sender......for FREE! thanks again.
post #5 of 7 Old 02-16-2008, 11:32 PM
imprezive591 is an unknown
Send a message via AIM to imprezive591
alright another ???, where would one connect the wire, since there is'nt a mechanical boost line, for the gauge. I obviously know the power wires and what not, but where's the best place to connect the sensor wire for reading the boost?
imprezive591 is offline
post #6 of 7 Old 02-17-2008, 10:07 AM
i ran my wires inside the firewall and tapped into the ignition switch
nagyhead is offline
post #7 of 7 Old 02-17-2008, 10:22 AM
Longshot's Avatar
+1 nagy, i've seen this happen quite a bit from prosport.
DTRacing Tuned
Longshot is offline
