Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 06-18-2009, 06:03 PM   #1 (permalink)
Reputation: alexxxphilly is an unknown
Send a message via AIM to alexxxphilly
Help! Drivers side got soaked!!!!!!!!!!!
It rained the whole day, so an hour ago got in my car and bam! Under the pedals all soaked!!! Weird ### only it's a circle and nothing on the sides! And I didn't leave the door open or window! Help!
Does this ever happen to you guys?!
Where do I look?! Pics will help!
I opened the hood and noticed the right side it's kinda wet I don't thinks normal.
It's 100% water not other fluid
Old 06-18-2009, 07:08 PM   #2 (permalink)
Timeslip: 9.999 @ 101.26
Check all your rubber linings to make sure they are in place and not torn, you might want to lift the carpet up and see if there is a hole in your floorboard from the previous owner unless you're the first owner.
I know the dodge neon i used to have would have the floorboard soaked and it turned out to be from a hole in the floor board. Also check to make sure all your a/c condensation lines lead to the outside and not the inside.
Old 06-18-2009, 07:22 PM   #3 (permalink)
I will lift the carpet prly tom... One thing though, I parked my car n next day (today) got in n was all wet. I didn't move the car so even if there's a hole under couldn't got wet cause I didn't move it! Idk it's weird..
