help! - Subaru WRX Forum
post #1 of 8 Old 04-04-2006, 05:25 PM Thread Starter
subiespike's Avatar
subiespike is an unknown
help!
alright....I put a turbo xs tmic on the car today and made sure everything was tightened.. now my car threw a check engine light at me and it runs like crap. so i dissconected the battery for a while and the light turned off, but still runs like crap... what do I do????
subiespike is offline
post #2 of 8 Old 04-04-2006, 06:58 PM
bigbadbuddha's Avatar
Images: 15
First off, we need to know what the cel was? Second, what mods have you done to your car?
When you throw the cel again have it read. Only thing I can suggest is put your stock one back one. The stock IC is good up until you start to change your turbo injectors, and fuel pump.
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #3 of 8 Old 04-04-2006, 07:47 PM Thread Starter
subiespike's Avatar
i have an hks turbo back exhaust with hks up pipe and down pipe. short ram air intake and super AFC 2. I mean the light hasnt came on for a while and it seems to be running a bit better, it just seems to be holding back... if that makes sense
post #4 of 8 Old 04-04-2006, 08:39 PM
Images: 15
For what you have the larger top mount is not necessary. I'd put the stock back one on for now and see if it makes things better. There will be a little more lag with the larger intercooler. Whether that is the problem or not I'm not sure. Other than that check everything again and make sure something isn't leaking or loose.
Big Jae -
post #5 of 8 Old 04-04-2006, 11:00 PM
nick4592's Avatar
It just isn't put on correctly....a loose or disconnected intercooler hose will cause the car to run like poo or not at all
nick4592 is offline
post #6 of 8 Old 04-05-2006, 02:22 AM
joker97's Avatar
joker97 is an unknown
does it need a change to engine management w new intercooler?
joker97 is offline
post #7 of 8 Old 04-05-2006, 07:46 AM
ManicsWrX's Avatar
ManicsWrX is more helpful than not
No EM is needed though what he is explaining is the lag caused by a Larger IC with the stock turbo. There is no need to change the IC as of yet. You will see alot more lag with this TMIC put on. I would suggest putting stock one back on until you upgrade your turbo then put the new TMIC on. Until then run stock IC with Stock turbo. Good luck with it. and again you WILL see quite a bit more lagg being that this is a larger TMIC
Chris- ▼SbiΣ Mi▼
242 AWHP / 318 TQ
ManicsWrX is offline
post #8 of 8 Old 04-06-2006, 06:15 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
You really should get your car tuned for the mods you have and the new TMIC
Ian is offline
