GFB BOV knocking/Rattle - Subaru WRX Forum
post #1 of 7 Old 02-29-2004, 02:17 PM Thread Starter
WizzD's Avatar
Send a message via AIM to WizzD
Unhappy GFB BOV knocking/Rattle
Hey guys. My GFB BOV has been on for about a year. For some reason, just this past week, it began to rattle and knock. When I look under the hood as it's running idle, I can see the inside where it normally opens up to release quickly jumping or rattling around. I'm not sure what has suddenly caused this but the noise is loud enough to hear from in the car at idle and out of the car even with the hood closed and doors closed. I removed it and tried to be sure all connections were tight and lubricated but to no avail when I put it back on, same knocking/rattle. Any other suggestions before I take it back to the dealer that put it on for a fix or possible replacement? Thanks.
WizzD is offline
post #2 of 7 Old 03-07-2004, 06:19 PM Thread Starter
WizzD's Avatar
Anyone?
WizzD is offline
post #3 of 7 Old 03-07-2004, 09:25 PM
Kobiyashi's Avatar
besides that is the valve working properly? I also know you stated you lubed it, did you notice anything cracked or loose?
Kobiyashi is offline
post #4 of 7 Old 03-08-2004, 05:07 AM
BlueDemon's Avatar
Normal. Mine does the same thing. So long as it is not functioning irregularly, then I wouldn't be so concerned. It's weird though, as mine used to do it, now has stopped. Just give it a while, or get rid of it, because it's something they seem to do.
Blue
BlueDemon is offline
post #5 of 7 Old 03-08-2004, 06:45 AM Thread Starter
WizzD's Avatar
I didn't notice anything cracked or loose when I took it off. It just doesn't seem like a normal thing to me. I see it's happened to some of you as well. I hope it just goes away. If not soon, I'm going to replace it with another.
WizzD is offline
post #6 of 7 Old 03-11-2004, 10:44 AM Thread Starter
WizzD's Avatar
Well, the rattle/knocking around hasn't gotten' any better to it's gonna' be @ the Subie dealer where it was purchased and installed. Droppin' it off tonight after work and they're gonna' look at it tomorrow. I'll post the details when I get it back.
WizzD is offline
post #7 of 7 Old 03-12-2004, 03:46 PM Thread Starter
WizzD's Avatar
Solved!
Well, got the car back and the bypass hose plug was hitting the BOV and causing the rattle. They removed it all, cleaned it, re-adjusted everything and re-installed. All is right with the world again.
WizzD is offline
