Fuel for WRX engine in non wrx car - Subaru WRX Forum
post #1 of 9 Old 02-05-2004, 08:13 PM Thread Starter
jpwzq8 is an unknown
Send a message via AIM to jpwzq8
Ok my cousin has this kit car porsche looking like thing that he put a wrx engine in. Had a VW engine to begin with. He then found out he dosent have enought time for the swap so, He ask me if i wanna make a few $$$ im like sure. light ass car and 230 hp . Body its all fiberglass. Well i have a few question on hooking the feul up for this beeyotch. I see that their are 3 lines which look like they would be for fuel, located buy the oil fill cap and dip stick.
I know their should be a Fuel in and Return but what is the third one for?
Could some one explain or maybe draw me a picture of what lines if for what.
Also what would be a good inline fuel pump for this engine. My cousin bought a Intank pump which isnt going to work or its to much work to make it work.
Also is a fuel pressure regultor needed if so what would be a good choice for that?
Thanks for any input you many supply me with
jpwzq8 is offline
post #2 of 9 Old 02-06-2004, 09:00 AM
fc735's Avatar
the third one, is the smallest....its a vapor line for the evap system.
not needed.....you have a pressure line, which is the one that goes to the rail, and the one that leaves the regulator is the return line.
the stock regulator will work fine....
as for a fuel pump, you will need to get an inline high pressure pump....capable of about 55-60psi.
fc735 is offline
post #3 of 9 Old 02-06-2004, 11:04 AM Thread Starter
Where is the stock regulator located? Or are the 3 fuel lines by the oil fill cap attacted to the regulator?
jpwzq8 is offline
post #4 of 9 Old 02-06-2004, 12:21 PM
fc735's Avatar
they are connected already. there are two of them that are 5/16" fitting, those are the two for the fuel lines.
gimme a while and i will see which ones are which...mine isnt stock anymore.....
fc735 is offline
post #5 of 9 Old 02-08-2004, 10:50 PM Thread Starter
Were can i find a fuel pump like that?
jpwzq8 is offline
post #6 of 9 Old 02-09-2004, 01:00 PM
fc735's Avatar
fc735 is offline
post #7 of 9 Old 02-09-2004, 06:16 PM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
You're going to need at least 60 on a stock turbo, 70+ on aftermarkets; or insane Injector size to make up the IDC.
Stock turbo at 16psi will run you 59psi on fuel.
-kobi
Kobiyashi is offline
post #8 of 9 Old 02-09-2004, 07:13 PM Thread Starter
http://store.summitracing.com/partde...rt=ACC%2D74701
its says its only 45 psi how is that suppose to work if I need 60 psi?
jpwzq8 is offline
post #9 of 9 Old 02-09-2004, 07:30 PM
Kobiyashi's Avatar
Don't know much on that brand, Walboro's hit 75-80 PSI.
You can pick one up for $90's 255lph High Pressure.
-kobi
