Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
WrxTuners.com is the premier Subaru WRX forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-03-2010, 03:40 PM   #1 (permalink)
Car: 05 WRX
Reputation: FranzKlammer is an unknown
fuel pump issues
2005 WRX Sedan won't start, so when I disconnect both fuel lines at the motor, no fuel coming out when the motor is turned on. I have tracked power to the wire connector under the rear seat, but can't get any power to show up at either fuel tank cover. I pulled both fuel tank cover plates and disconnected both wire connectores but can't find any power, so I think the fuel pump needs power to run. Any ideas ?
Old 07-06-2010, 11:24 AM   #2 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is more helpful than not
Have you pulled the pump and filter out yet ??
Old 07-06-2010, 01:28 PM   #3 (permalink)
wagonracer's Avatar
Timeslip: 9.999 @ 92.412
Reputation: wagonracer is known to be trustworthy and helpful wagonracer is known to be trustworthy and helpful wagonracer is known to be trustworthy and helpful
First thing I would check is fuses and relays, if they're good, then I would take the pump out and connect it to a hot 12v source (battery) to see if it runs. That will determine that the problem is in the wiring harness or ECU. Troubleshooting from there gets a lot more complicated
Old 07-06-2010, 09:56 PM   #4 (permalink)
Car: 05 WRX
I took the pump out this morning and hooked up a battery and it pumped just fine. So I ran a couple of new wires to it back in the car and it ran just fine. I did get two new codes
P0183-Fuel Temperature Sensor A Circuit High Input
P0230-Fuel Pump Primary Circuit Malfunction -- huh ?
Where do I get a manual for this car, a good one ?
Old 07-06-2010, 11:44 PM   #5 (permalink)
wagonracer's Avatar
complete shop manuals can be found at Impreza Manuals | ken-gilbert.com I'm not sure if the '05 is there, but very few changes were made between '02 and '05
Old 07-07-2010, 10:16 PM   #6 (permalink)
Car: 05 WRX
Thanks, so when I look at the engine from the front of car, which fan on the radiator is AC. I want to wire that side with a switch and remove the AC pump. Thanks, again
