-   -   fuel pump issues (http://www.wrxtuners.com/forums/f72/fuel-pump-issues-29067/)
FranzKlammer 07-03-2010 03:40 PM
fuel pump issues
2005 WRX Sedan won't start, so when I disconnect both fuel lines at the motor, no fuel coming out when the motor is turned on. I have tracked power to the wire connector under the rear seat, but can't get any power to show up at either fuel tank cover. I pulled both fuel tank cover plates and disconnected both wire connectores but can't find any power, so I think the fuel pump needs power to run. Any ideas ?
pzr2874 07-06-2010 11:24 AM
Have you pulled the pump and filter out yet ??
wagonracer 07-06-2010 01:28 PM
First thing I would check is fuses and relays, if they're good, then I would take the pump out and connect it to a hot 12v source (battery) to see if it runs. That will determine that the problem is in the wiring harness or ECU. Troubleshooting from there gets a lot more complicated
FranzKlammer 07-06-2010 09:56 PM
[quote=wagonracer;247389]First thing I would check is fuses and relays, if they're good, then I would take the pump out and connect it to a hot 12v source (battery) to see if it runs. That will determine that the problem is in the wiring harness or ECU. Troubleshooting from there gets a lot more complicated[/quote]
I took the pump out this morning and hooked up a battery and it pumped just fine. So I ran a couple of new wires to it back in the car and it ran just fine. I did get two new codes
P0183-Fuel Temperature Sensor A Circuit High Input
P0230-Fuel Pump Primary Circuit Malfunction -- huh ?
Where do I get a manual for this car, a good one ?
wagonracer 07-06-2010 11:44 PM
complete shop manuals can be found at [url=http://ken-gilbert.com/impreza-manuals]Impreza Manuals | ken-gilbert.com[/url] I'm not sure if the '05 is there, but very few changes were made between '02 and '05
FranzKlammer 07-07-2010 10:16 PM
[quote=wagonracer;247431]complete shop manuals can be found at [url=http://ken-gilbert.com/impreza-manuals]Impreza Manuals | ken-gilbert.com[/url] I'm not sure if the '05 is there, but very few changes were made between '02 and '05[/quote]
Thanks, so when I look at the engine from the front of car, which fan on the radiator is AC. I want to wire that side with a switch and remove the AC pump. Thanks, again
