Fuel Injectors - Subaru WRX Forum
post #1 of 9 Old 06-17-2011, 08:45 AM Thread Starter
GamerzBM's Avatar
Fuel Injectors
hello i have a 2002 wrx and i got misfires in all four cylinders i was looking at my fuel injectors and i have 3 blue ones and 1 pink sti one this could cause the misfires right??? and does anyone know where i can just get that 1 injector so i can take out the pink one
GamerzBM is offline
post #2 of 9 Old 06-17-2011, 09:02 AM
What CEL code and is it the same cylinder as the misfire..... Find this out first.
post #3 of 9 Old 06-17-2011, 09:11 AM Thread Starter
GamerzBM's Avatar
EDIT: I just pulled the codes and its
PO302
PO303
PO304
PO457
PO302
PO303
PO304
thats what i just pulled
GamerzBM is offline
post #4 of 9 Old 06-17-2011, 09:34 AM
Ok,
Did you just buy the car or did you mess with the injectors?
Can't believe someone would mix injectors. Wait... yes I can.
Look on NASIOC for a set of 440cc injectors.
Do you have engine management or a tune on the car ?
Search would have netted this for starters:
P0457 CEL Help.
post #5 of 9 Old 06-17-2011, 09:54 AM Thread Starter
GamerzBM's Avatar
i had the car for over a year i just rebuild the cams becuase someone put the timing belt of wrong and everything smashed so when i put the car all back together the misfires happen and everything is stock from what i know i havent done anything its does have a cold air intake no tune no engine management
GamerzBM is offline
post #6 of 9 Old 06-17-2011, 10:05 AM
Do you have the stock airbox/ram air ? If so, throw it back on.
Read that thread/link and then look for the correct injectors (seen them as low as $100).
post #7 of 9 Old 06-17-2011, 10:13 AM Thread Starter
GamerzBM's Avatar
no i dont have the stock airbox
GamerzBM is offline
post #8 of 9 Old 06-17-2011, 10:15 AM
I can't get on NASIOC to help you look. But they (boxes and Injectors) are all over the place. I have a buddy selling his box and ram. If you are interested PM me.
Maybe someone else can look on NASIOC for you.
post #9 of 9 Old 06-18-2011, 08:16 PM
AllExtinct's Avatar
Check on E-bay for a used stock box. People are always selling stock boxes on there after they buy aftermarket intakes. So you can benefit for some others soon be misfortune. !Laugh!
Sometimes you can pick up some injectors also.
Good luck man.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
