Fuel cut - Subaru WRX Forum
post #1 of 5 Old 05-18-2010, 10:02 AM Thread Starter
White02's Avatar
White02 is an unknown
Send a message via AIM to White02
Fuel cut
So im on my way home from work and punched the gas it was fine until I herd a pop and the fuel cut. now it won't let me boost over 5 psi and the bov is 3 times louder I can't see anything abnormal and it seams to run fine other than that. Any ideas?
No CEL's came on
My car is stock other than suspension work and a turbo back.
White02 is offline
post #2 of 5 Old 05-18-2010, 10:11 AM
Sounds like you ruptured a hose or a gasket failed, something like that. Have you checked the BOV for leaks?
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
post #3 of 5 Old 05-18-2010, 11:18 AM Thread Starter
White02's Avatar
Thats what I was thinking the car idols fine and there isn't any vacume leaks. How do you check the BPV?
White02 is offline
post #4 of 5 Old 05-18-2010, 12:35 PM
Some leaks will only occur at pressure. If you are saying that you can't get past 5psi I would imagine your leak opens enough for air to escape at 5psi. You should do a pressure test.
Ryan
VisiX is offline
post #5 of 5 Old 05-18-2010, 12:41 PM Thread Starter
White02's Avatar
That makes sence I'll have to check it tonight thanks. How exactly would I go about doing a pressure check on that?
White02 is offline
