First gear noise - Subaru WRX Forum
post #1 of 5 Old 01-12-2011, 07:47 PM Thread Starter
ta1129wrx is an unknown
First gear noise
Hello everyone i have a quick question that i hope someone can help me with. Their is a noise that sounds like its coming from my rear when i completely release the clutch on first gear. It only happenes when i park the car for about 10-15 min or longer when im in reverse it dosent do it nor dose it do it on any other gear just first. it sounds almost like i ran somthing over an it lightly tapped the undercarage of the car its not a loud loud noise if i have the radio on i cant hear it but its the fact i know its their and the odd thing is that when i drive a 100 feet it wont do it again. i have nothing stuck under my car and it looks like nothing is rubbing as i can see. any clue?
ta1129wrx is offline
post #2 of 5 Old 01-12-2011, 08:11 PM
does the car have a... surge or single shake that happens at the same time? Sounds like you're describing the Subaru "Bucking". The usual fix is a good tune, factory tunes are shit.
post #3 of 5 Old 01-12-2011, 11:06 PM Thread Starter
yeah somtimes it dose do it on a shake but it also dose it when its smooth.
post #4 of 5 Old 01-18-2011, 01:22 PM
Hondafan's Avatar
Is it like a knock? I don't completely understand the noise you're describing. If it's a knocking then it could be CV axles starting to go, and then once the grease warms up a bit it stops?
Hondafan is offline
post #5 of 5 Old 01-19-2011, 11:55 PM Thread Starter
it sounds like when you hit a door stopper on your walls the one that has springs an it makes that noise its almost like a its somthing in my clutch but im dropping it back to the dealership
