A few problems with newly purchased WRX '09 Wagon - Subaru WRX Forum
post #1 of 8 Old 06-25-2012, 01:39 PM Thread Starter
TWREX is an unknown
Hey guys,
I have noticed a few minor issues with our new WRX. It has 25xxx miles on it. It is a very clean car and looked to have been well taken care of. But I'm no expert in automotive by any means.
Problem 1: When under full acceleration, I can feel a slight miss at about 4500-5000RPM, I dont think it's anything major, but it is noticeable.
Problem 2: When Idling, I can hear what I believe to be the throwout bearing chirping. It's a light chirping noise that stops when I put pressure on the clutch pedal. Will an extended warranty cover this repair? Any experience with similar problems?
Problem 3: I can hear a rubbing noise when I turn to the right. I dont hear it when turning left. Wheels are stock size, so i dont think there should be any clearance isssues with anything.
Note: I did not notice any of this while test driving the car and Ive only had it for about 2 weeks. Any help is greatly appreciated. Thanks
TWREX is offline
post #2 of 8 Old 06-25-2012, 01:48 PM
Originally Posted by TWREX View Post
Hey guys,
Problem 1: When under full acceleration, I can feel a slight miss at about 4500-5000RPM, I dont think it's anything major, but it is noticeable. Any CEL's?
Problem 2: When Idling, I can hear what I believe to be the throwout bearing chirping. It's a light chirping noise that stops when I put pressure on the clutch pedal. Will an extended warranty cover this repair? Any experience with similar problems? Does it matter if it's IN gear or not?
Problem 3: I can hear a rubbing noise when I turn to the right. I dont hear it when turning left. Wheels are stock size, so i dont think there should be any clearance isssues with anything. Look at the wheel liner, if not... any marks on the tire?
See in bold
post #3 of 8 Old 06-25-2012, 02:13 PM Thread Starter
TWREX is an unknown
No CEL.
Does not matter if it's in gear or not.
No visible rub marks. But I did find some plastic shields that are missing the plastic retainers that could be causing some noise.
TWREX is offline
post #4 of 8 Old 06-25-2012, 03:33 PM Thread Starter
TWREX is an unknown
Problem 3 has been resolved. It was the loose plastic shields in the wheelwell causing the noise.
Some more info on problem 2: It stopped chirping for a while and then just started doing it again. It will repeatedly stop making the noise, then start up again. I can also hear the chirping when driving. Not sure if this helps.
TWREX is offline
post #5 of 8 Old 06-26-2012, 05:46 AM
Is it still under warranty? Glad you found the wheel liner issue.
post #6 of 8 Old 06-26-2012, 07:46 AM
bad grocerygetter's Avatar
As far as the slight miss, if the spark plugs haven't been done yet its about time.
Kevin.
bad grocerygetter is offline
post #7 of 8 Old 06-28-2012, 10:38 PM Thread Starter
TWREX is an unknown
I'll definitely try some new plugs. Like you said it could probably use them anyway. Warranty just expired, although I did purchase an extended warranty. However, it doesn't cover clutch components. They are considered a regular wear out item, for lack of a better term. So I may have to just fork out the 1200$ for a clutch job....!Cry!
TWREX is offline
post #8 of 8 Old 07-08-2012, 11:09 AM Thread Starter
TWREX is an unknown
I just finished reading a huge thread on ClubWRX that included numerous horror stories about clutch failures at 5-20k miles. Some got covered by warranty and failed again. Some blame the organic clutch compound. Would it be worth it to just have a SPEC clutch installed? Would I be ahead later on down the road. Replacing a clutch every 20k miles is not my idea of a good time.
TWREX is offline
