Extreme Engine Problems... - Subaru WRX Forum
post #1 of 12 Old 11-30-2009, 08:05 AM Thread Starter
wfocory's Avatar
wfocory is an unknown
So i've been searching for about 3 hours now and I decided to just ask.
So I just finished putting my car back together and even had a subaru tech help me. How ever when I start it, it idles really rough and sounds like its drowning its self. I up'd timing and cut fuel but i still am running way to rich. Also if i get on the gas a little it only builds about 5 psi and maybe revs to 2800rpms and cuts. I can't figure out what my problem is. Please help.
wfocory is offline
post #2 of 12 Old 11-30-2009, 04:36 PM
ratfink's Avatar
ratfink is a helpful contributing member
Could be anything, what was done to it? Was the ecu reset? Are the sensor all plugged in etc. Any check engine light? how long have you let it run?
Brad
ratfink is offline
post #3 of 12 Old 11-30-2009, 08:17 PM Thread Starter
wfocory's Avatar
1000cc fuel injectors, 255 fuel pump, port and polished heads, head studs, tactrix tuning cables, front mount
i let it run for about 30 mins
i have cel because i have no o2 sensor
wfocory is offline
post #4 of 12 Old 11-30-2009, 08:26 PM
No exhaust, no turbo upgrade? Just seems like an odd upgrade path. If you have the tatrix cable have you logged/checked everything out?
post #5 of 12 Old 11-30-2009, 09:11 PM
ratfink's Avatar
You probably need to ramp down the fuel trim ALLOT with that setup. Did you flash a map set for that kind of flow? Sounds like just a tune issue to me.
Brad
ratfink is offline
post #6 of 12 Old 12-01-2009, 01:00 AM
definitely a tuning issue...if you can post a log I can try and help you out
post #7 of 12 Old 12-01-2009, 01:53 AM
His profile says a custom TBE and a T70 turbo
post #8 of 12 Old 12-01-2009, 08:14 PM
My bad Kirt I realized that after I posted it, but thats a massive turbo for a small 4 cylinder.
post #9 of 12 Old 12-01-2009, 11:18 PM
it certianly is
post #10 of 12 Old 12-11-2009, 01:46 PM Thread Starter
wfocory's Avatar
We have been data logging for a few weeks now but for some reason its still not running right. I'm sending it to Tommy Motorsports to have them look at it. We turned down the fuel injectors to 500cc on the tune and advanced some timing and opened the maf all the way and some other things. I don't tune my two friends do. Anyways it will run lean like 17's on my airfuel when i barely push the gas where it should be 14's and if I accidently tap the gas to much it wants to flood out. I also found I had some boost leaks and somethings were not connected.
"Every place I take my car and people look under the hood they all ways say, "Look at that ungodly sized turbo! Do you even spool it? I just laugh and say that there is a lot of foreplay."
wfocory is offline
post #11 of 12 Old 12-11-2009, 02:08 PM
VD5505's Avatar
you are running a MAF on this car?? are you tunning this on a dyno at all??
VD5505 is offline
post #12 of 12 Old 12-11-2009, 08:06 PM
pb-king07's Avatar
pb-king07 is an unknown
you still did not say what kinda cels it was giving you. are you sure your not off on your timing
pb-king07 is offline
