Engine swap question - Subaru WRX Forum
post #1 of 7 Old 12-25-2011, 07:39 AM Thread Starter
WRXInfantryGuy's Avatar
WRXInfantryGuy is an unknown
I just had a engine swap done but my car seems to be slower could this be a tuning issue
TJ Butler
WRXInfantryGuy is offline
post #2 of 7 Old 12-25-2011, 09:36 AM
It could be a number of things. Bad engine, bad tune, something not connected.
Just because it seems slow doesnt really make it slow either. My car with a 20G pushing 20PSI seems slow to me at days, but thats cause I get use to the power. Check ever last connection, ever line, be it power, or vacuum lines. Start simple and work up to the bigger things.
post #3 of 7 Old 12-25-2011, 07:38 PM
what swap did you have done? were any other parts changed? like josh said there could be any number of things causing the reduced power
post #4 of 7 Old 12-26-2011, 11:11 AM
Is it on a break-in map? To break in the new engine? Who did the engine swap and if it was a tune shop. Maybe they throttled back boost to make sure you don't beat on the new engine. Which wouldn't be a bad idea because your pistons will probably leave little shavings in the oil until you run it and flush the oil once or twice.
post #5 of 7 Old 12-26-2011, 06:15 PM Thread Starter
U had the engine swap done at a mom n pop shop I'm sure it just needs a tune I checked the lines there all fine although I did notice blow back buildup Arron's the alternator but the power steering pump is bad so I assume that's the cause not really sure tho
TJ Butler
post #6 of 7 Old 12-27-2011, 05:29 PM
I wouldn't even be surprised if they cracked the stock turbo inlet and maybe that's the cause of your loss of power.
post #7 of 7 Old 12-28-2011, 06:00 AM
What did they swap out specifically ? Just a newer EJ ?
What's this "mom and pop" shop that did this may I ask ?
