Engine rattle? - Subaru WRX Forum
 2Likes
post #1 of 16 Old 03-05-2014, 06:47 AM Thread Starter
Engine rattle?
hello i own an 03 wrx and i have a slight rattle once i let off the gas, its been going on for a week. when i give the car gas it will rattle when the RPMs are going down. any ideas?? its a stock BOV
justin93m is offline
post #2 of 16 Old 03-05-2014, 07:19 AM
Video?
post #3 of 16 Old 03-05-2014, 07:31 AM Thread Starter
i cant upload a video, but when the rpms drop it rattles like theres a beebee in there
post #4 of 16 Old 03-05-2014, 10:29 PM
Light weight flywheel?
post #5 of 16 Old 03-06-2014, 12:35 AM
Sub14WRX's Avatar
it could be a number of things. but my guess if its def coming from the block. could be a bearing issue somewhere in there.
Sub14WRX is offline
post #6 of 16 Old 03-06-2014, 08:30 AM Thread Starter
it sounds like its around the turbo/downpipe area? but it doesnt do it extremely loud like i can barley hear it while im driving but if i life the hood and pull the throttle then ill hear it, my performance isnt affected by it still runs good
post #7 of 16 Old 03-06-2014, 09:10 AM
Premium Member
arewmors's Avatar
Maybe the heat shield around the turbo has loosed up just a little to cause rattle.
the RIOT act likes this.
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #8 of 16 Old 03-06-2014, 09:28 AM Thread Starter
im not too sure the turbo has a heat shield, it was just replaced a few months ago. it kinda sounds like a bolt is loose and rattling around. but id really like to fix it and living in Central PA its hard without a garage hah
post #9 of 16 Old 03-06-2014, 09:32 AM
Premium Member
arewmors's Avatar
There's nothing covering your turbo? Even if they replaced the turbo they should have reinstalled your heat shield
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #10 of 16 Old 03-06-2014, 09:36 AM Thread Starter
it has no turbo blanket or anything, it does sound kinda like a berring rattling around but wouldnt it have some kind of mechanical problem?
post #11 of 16 Old 03-06-2014, 11:05 AM
Premium Member
arewmors's Avatar
If your turbo was just replaced a few months ago, and the noise is coming from where the turbo is maybe you should take it back to the place that installed the turbo. Was it a new turbo or used?
Andy - 12 WRB WRX
294 AWHP / 311 TQ
arewmors is offline
post #12 of 16 Old 03-06-2014, 11:41 AM Thread Starter
it was a used TD04
post #13 of 16 Old 03-06-2014, 03:59 PM
06_hawk_eye's Avatar
Where are you located in pa? I had a similar noise turned out to be the plug in the aftermarket down pipe where a 02 can go. Just had to tighten the bolt that was in the hole. Could be the heat shield on the up pipe as well
Sent from AutoGuide.com App
06_hawk_eye is offline
post #14 of 16 Old 03-07-2014, 07:50 AM Thread Starter
i am located in the Altoona/State college area. and i had a feeling it might be my shield on my up pipe as well
post #15 of 16 Old 06-06-2014, 03:25 AM
I had that problem too but turn out to be my turboxs bov. It was rattling I add another washer and noise went away.
Htown is offline
