-   -   Engine rattle? (http://www.wrxtuners.com/forums/f72/engine-rattle-45561/)
justin93m 03-05-2014 07:47 AM
Engine rattle?
hello i own an 03 wrx and i have a slight rattle once i let off the gas, its been going on for a week. when i give the car gas it will rattle when the RPMs are going down. any ideas?? its a stock BOV
brfatal 03-05-2014 08:19 AM
Video?
justin93m 03-05-2014 08:31 AM
i cant upload a video, but when the rpms drop it rattles like theres a beebee in there
brfatal 03-05-2014 11:29 PM
Light weight flywheel?
Sub14WRX 03-06-2014 01:35 AM
it could be a number of things. but my guess if its def coming from the block. could be a bearing issue somewhere in there.
justin93m 03-06-2014 09:30 AM
it sounds like its around the turbo/downpipe area? but it doesnt do it extremely loud like i can barley hear it while im driving but if i life the hood and pull the throttle then ill hear it, my performance isnt affected by it still runs good
arewmors 03-06-2014 10:10 AM
Maybe the heat shield around the turbo has loosed up just a little to cause rattle.
justin93m 03-06-2014 10:28 AM
im not too sure the turbo has a heat shield, it was just replaced a few months ago. it kinda sounds like a bolt is loose and rattling around. but id really like to fix it and living in Central PA its hard without a garage hah
arewmors 03-06-2014 10:32 AM
There's nothing covering your turbo? Even if they replaced the turbo they should have reinstalled your heat shield
justin93m 03-06-2014 10:36 AM
it has no turbo blanket or anything, it does sound kinda like a berring rattling around but wouldnt it have some kind of mechanical problem?
arewmors 03-06-2014 12:05 PM
If your turbo was just replaced a few months ago, and the noise is coming from where the turbo is maybe you should take it back to the place that installed the turbo. Was it a new turbo or used?
justin93m 03-06-2014 12:41 PM
it was a used TD04
06_hawk_eye 03-06-2014 04:59 PM
Where are you located in pa? I had a similar noise turned out to be the plug in the aftermarket down pipe where a 02 can go. Just had to tighten the bolt that was in the hole. Could be the heat shield on the up pipe as well
justin93m 03-07-2014 08:50 AM
i am located in the Altoona/State college area. and i had a feeling it might be my shield on my up pipe as well
Htown 06-06-2014 04:25 AM
I had that problem too but turn out to be my turboxs bov. It was rattling I add another washer and noise went away.
