Engine making a ticking noise. Video Clip! - Subaru WRX Forum
post #1 of 14 Old 05-28-2011, 04:43 PM Thread Starter
WRX 56308's Avatar
Question Engine making a ticking noise. Video Clip!
Stock 09 WRX.
I just bought it 2 weeks ago to the day. I've never noticed this noise until last night. I'm just wondering if this is normal. The sound is coming from both sides of the engine. I searched around and couldn't find any topics that really pertained to this issue. To me, it sounds a little like lifter noise like on a V8, but these are OHC engines, so that can't be it.
Any help or information is greatly appreciated. I don't want to drive an hour to my Subaru dealer if it's nothing to worry about.
Here's a video clip.
WRX 56308 is offline
post #2 of 14 Old 05-28-2011, 05:43 PM
Sounds like a lot of valve tap. But, its hard to tell because it sounds like a lot fan in the video also. Flat-4s can have a lot of valve tap at times. Sometimes changing your oil to a better kind will get rid of it.
post #3 of 14 Old 05-28-2011, 06:23 PM Thread Starter
WRX 56308's Avatar
The dealer uses 5w30 synthetic. Is valve tap something to worry about? Sorry, this is my first OHC vehicle.
post #4 of 14 Old 05-29-2011, 12:21 PM
shaggy's Avatar
it's normal. the one i test drove and the one i bought both sounded like that when they had under 100 miles on them. i've got over 30k on mine now and it sounds the same.
SHAGGY
14 STi Hatch
shaggy is offline
post #5 of 14 Old 05-30-2011, 10:01 PM
Yeah, its normal.
post #6 of 14 Old 05-30-2011, 10:14 PM Thread Starter
WRX 56308's Avatar
Alright, I won't worry about it so much then. Thanks!
post #7 of 14 Old 05-30-2011, 10:29 PM
Its called the subaru tick. It confuses a lot of first time buyers at times.
post #8 of 14 Old 05-31-2011, 03:54 AM Thread Starter
WRX 56308's Avatar
After doing some more reading, could using 89 instead of 91 cause this? The fuel door on the car says to run no less than 91. When i filled up, 89 was the highest available. I was on a road trip and small towns = 89 if you're lucky out here.
post #9 of 14 Old 05-31-2011, 11:47 AM
jonathang's Avatar
You can run 89 if necessary as long as its not too hot outside and you are not really pushing the engine. But, then put some 91 in as soon as you can.
jonathang is offline
post #10 of 14 Old 05-31-2011, 01:58 PM
sicc_soul's Avatar
um, with how picky these motors are, I would never run less than 91 octane.
Have to be young and stupid to be old and wise
sicc_soul is offline
post #11 of 14 Old 05-31-2011, 02:30 PM Thread Starter
WRX 56308's Avatar
I realize that sicc soul. It was either 89 or nothing, didnt really have a choice. Would some octane boost help, or is that even worth it?
post #12 of 14 Old 05-31-2011, 04:36 PM
Damn, yeah...I'd say 89 oct probably would make it knock/tick louder than normal. Octane booster doesn't do as good as a job as its advertised. But, you could give it a try.
post #13 of 14 Old 06-01-2011, 05:43 AM
Actually, you "could" try a gallon of corn and then fill up on 89... might help if they had it there.
post #14 of 14 Old 08-13-2015, 05:48 PM
I have a 2015 wrx base and today just now when i started the car it makes that same ticking noise but i dont know where its coming from, it never made that noise before and if it did, then it wasnt that loud. I put royal purple synthetic oil in it every 3k miles and use the highest grade gas, i think its 93 octane, and i only fill up at shell gas stations. I checked the oil, its fine, not too dirty, i have 1k more miles until oil change, is this something i should be worried about? I also have a pro tune, full turboback exhaust, intake, and tgv deletes, i dont rag the piss out of it but i do get on it time to time on the highway ramps n stuff. Please let me know what your inputs are. Thanks
demobp is offline
