Engine GonE???? - Page 2 - Subaru WRX Forum
post #16 of 45 Old 06-27-2011, 10:10 AM
Well my noise didn't get louder, it just the noise frequency increased when the rpms increased. Its why I'm hoping its just bearings because it didn't get ugly loud with rpms. Even with increased rpms it was quieter than this wrx in the video.
post #17 of 45 Old 06-27-2011, 02:45 PM Thread Starter
GamerzBM's Avatar
GamerzBM is an unknown
no i didnt do the metal thing but i tried to check the timing but the timing cover wouldnt come off the bolt is like stripped or something it just kept turning and turning any ideas on how to get it off
GamerzBM is offline
post #18 of 45 Old 06-27-2011, 08:37 PM
If you can, the easiest of things like that is to try and put a flat tip screw driver under the head of the bolt and apply up ward pressure to see if you can get another or more threads to grab.
post #19 of 45 Old 06-27-2011, 08:42 PM Thread Starter
GamerzBM's Avatar
alright thanks im going to try that tomorrow and also going to drain my oil to see if theres any metal in in
GamerzBM is offline
post #20 of 45 Old 06-27-2011, 08:45 PM
If that doesnt work let us know. I work on helicopters and thats usually one of the first things I try to get stuck bolts/screws out. Its usually one of the easiest and less destrcutive ways. Good luck man.
post #21 of 45 Old 06-28-2011, 10:30 PM Thread Starter
GamerzBM's Avatar
I drained the oil to check for metal i used a magnet and it was clean no metal so does this mean its not the bearings?
GamerzBM is offline
post #22 of 45 Old 06-28-2011, 10:44 PM
wagonracer's Avatar
Most likely, yes. How did the oil look ? Did you check the T-belt ?
Cullen
wagonracer is offline
post #23 of 45 Old 06-28-2011, 10:53 PM Thread Starter
GamerzBM's Avatar
oil was normal i guess it was a little dark but i changed oil on other cars and it looks the same and also the timing no because i cant get that damn cover off and i dont want to break it
GamerzBM is offline
post #24 of 45 Old 06-29-2011, 01:33 AM
If your metal had no gold sparklies in it then your bearings are most likely ok... I would get the sound sorted out ASAP though, if it's the t-belt tensioner and it goes, your whole engine is toast.
post #25 of 45 Old 06-29-2011, 10:09 AM Thread Starter
GamerzBM's Avatar
yea there was no metal so im glad thats not it i am going to try to look at this today try to get that bolt out
GamerzBM is offline
post #26 of 45 Old 06-29-2011, 12:51 PM Thread Starter
GamerzBM's Avatar
there is no other way for me to check the timing i can not get that screw out it sucks
GamerzBM is offline
post #27 of 45 Old 06-29-2011, 09:03 PM Thread Starter
GamerzBM's Avatar
Also it sounds like its coming from the a/c compresser
GamerzBM is offline
post #28 of 45 Old 06-29-2011, 09:21 PM
Take off the belt and see if it makes the sound anymore...
post #29 of 45 Old 06-29-2011, 09:30 PM Thread Starter
GamerzBM's Avatar
i can just take it off? lol like when it comes to taking things apart i get scared i dotn want to mess it up even more and also it connects to another pully in the middle or on the bottom of it im not sure but it is okay just to take it off?
GamerzBM is offline
post #30 of 45 Old 06-30-2011, 06:54 AM
Yes, all it does is keep the AC from running.
