Engine GonE???? - Subaru WRX Forum
post #1 of 45 Old 06-25-2011, 07:16 PM Thread Starter
GamerzBM's Avatar
GamerzBM is an unknown
Engine GonE????
hey guys i just had someone look at my car and he said that the motor is gone or something about bearings
here is a video please tell me what you guys think thanks the sound is coming from the driver side i thought it was the head but he said it wasnt
please let me know what you think thanks and if you are sure its that please tell me what i would have to do to fix it
GamerzBM is offline
post #2 of 45 Old 06-25-2011, 08:08 PM
What does you oil pressure gauge do when the car is running? Does it bounce back and forth?
post #3 of 45 Old 06-25-2011, 08:09 PM Thread Starter
GamerzBM's Avatar
i dont have my gauges hooked up yet
GamerzBM is offline
post #4 of 45 Old 06-25-2011, 08:16 PM
It sounds a little like rod knock man. Complete rebuild or a new shortblock are in order...
post #5 of 45 Old 06-25-2011, 08:18 PM
wagonracer's Avatar
Tough to tell from a vid, but at start-up and idle it sounds like rod knock. When you revved it, the sound quieted. Based on that I would guess the T-belt might be slack.
Two things I would do. Pull the two end timing covers, (turn the crank with a wrench 22mm) check your marks and feel the tension on the belt. Second, drain your oil and run a magnet through the oil and stick a small magnet in the drain hole to see how much (if any) metal you pick up. Those two will tell you a lot
Any codes ?
Cullen
wagonracer is offline
post #6 of 45 Old 06-25-2011, 08:24 PM Thread Starter
GamerzBM's Avatar
yes i am misfireing in 3 cylinders and running to lean someone else told me it could be my vavle timing is off and how much would a shortblock cost me?
EDIT: Also i just had the heads valves sealed and all fixed so it cant be those
GamerzBM is offline
post #7 of 45 Old 06-25-2011, 09:19 PM
wagonracer's Avatar
If the timing is off, it would be those actually. Pull the the covers....If that's what it is, you won't need a short block, you'll the valves done (correctly) Misfires are telling me that's your problem.
Cullen
post #8 of 45 Old 06-25-2011, 09:31 PM Thread Starter
GamerzBM's Avatar
just watched some videos online and it could be the belt tentioner or the belt idler? something like that im going to take a look at it tomorrow
GamerzBM is offline
post #9 of 45 Old 06-25-2011, 09:40 PM Thread Starter
GamerzBM's Avatar
valves were just done they cant be bent or anything because then the car wouldnt be drivable right????
GamerzBM is offline
post #10 of 45 Old 06-26-2011, 10:34 AM
That poor thing sounds sick. Best of luck with it!
post #11 of 45 Old 06-26-2011, 12:35 PM
Uff, that sounds way worse then what my car sounded like and my car is under the knife right now. For possible bearings replacement or rods. The engine builder has not let me know whats wrong with it yet. I'd do what the others suggested first and if that doesn't fix it. I'd say the engine needs pulled and inspected.
post #12 of 45 Old 06-26-2011, 02:03 PM
It honestly sounds like the tensioner to me.... If it is bad then there could be some collateral damage if the belt skipped a few teeth after the tensioner went bad.
99.99% of bearing failures will get louder and faster as rpm's rise and his sound went away when the rpm's were raised up..... On the other hand, most of the time the tensioner sound goes away as rpm's rise because the belt starts to spin faster and takes up the slack so the tensioner doesn't bounce as far.
post #13 of 45 Old 06-26-2011, 05:10 PM
wagonracer's Avatar
So, did you check your oil for metal and look at the timing marks ?
Cullen
post #14 of 45 Old 06-26-2011, 06:04 PM
True, my noise followed suit with rpms.
post #15 of 45 Old 06-26-2011, 06:48 PM
wagonracer's Avatar
Yeah, rod knock gets way uglier with revs
Cullen
