engine cranks but wont start.... any answers??? - Subaru WRX Forum
post #1 of 4 Old 11-22-2009, 06:08 PM Thread Starter
mabenation is an unknown
i just bought a 2002 impreza wrx yesterday and was driving it home on the freeway and it just shut off when i was driving all the electronics turned off. then tried roll starting and all electric went back on but no power in pedal. pulled over cranks but wont start. i noticed when i first started the car before i got it it sounded like it was running on 3 cylinders but the seller said thats how they ran. and it idled real lumpy and was sluggish off the line. checked one spark plug and it gets spark. checked fuses, checked fuel pump. tried using scanner to get codes but will not give any. check engine was flashing while driving. pulled one timin cover and marks were lined up. and aslo pos. battery terminal is really loose and needs replacement. any ideas what the problem could be????
mabenation is offline
post #2 of 4 Old 11-23-2009, 05:40 AM
could be a bad crank position sensor...but thats just a random guess
post #3 of 4 Old 11-23-2009, 10:01 AM
I hope you have more than a AS IS warranty. You should've got the car checked out before buying it.
post #4 of 4 Old 11-23-2009, 11:17 AM
04paulieWRX's Avatar
04paulieWRX is an unknown
injectors? timing? seems like your not getting fuel... . subarus do have a rough idle that sounds grumbly. its known as the boxer rumble...but i dont know if that was what you heard because you said it sounds sluggish. it also sounds like you could have more than one problem....the electronics going off sounds like a battery issue, the car not starting even though its cranking sounds like a whole other issue.
04paulieWRX is offline
