electrical tt related - Subaru WRX Forum
post #1 of 4 Old 01-03-2004, 11:58 AM Thread Starter
BlownFlat4 is an unknown
Send a message via AIM to BlownFlat4
i put a blitz dual tt in the other day, worked fine auto timed correctly no problems. took a long drive yesterday and on my way back almost home i noticed my blinkers were not working. hazards don't work, and the tt is not working. i have power to the dtt but no action after shut off. i checked all my fuses they are fine. any ideas?
Shaune
BlownFlat4 is offline
post #2 of 4 Old 01-03-2004, 08:12 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
Check the wire which goes to the hand brake. Also on the unit make sure you have A selected not B. And lastly just try resetting the ECU, that might do it.
Che
Tut4u2 is offline
post #3 of 4 Old 01-03-2004, 08:19 PM
fc735's Avatar
you pulled the radio trim off, no? you ###### unhooked the harness at the Hazard flasher.....i would check that first.
fc735 is offline
post #4 of 4 Old 01-05-2004, 09:30 AM Thread Starter
yeah later that night noticed the hazard led wasn't on... problem solved
Shaune
