Old 08-22-2008, 11:46 AM   #1 (permalink)
Reputation: BlueBooster is an unknown
Electrical Problem...
I have an issue with my 02 WRX...for some reason, my engine drains out my battery after a certain amount of time when im driving, (ABS light goes off, radio dies, and my radar turns on and off like crazy) bought a new battery and took the alternator into autozone for a test and they said its still good. Cleaned the corrosion around the positive cable and its still draining my battery. Has anyone came upon this issue yet? Could it be a bad wiring or a bad ground somewhere? i just recently change the power steering/alternator belt but somehow when i installed it i had to force it on, usually you don't have to force a belt on. Than after a while my engine began to get all dusty and thats when my battery began to drain out. Can anyone help me?
Old 08-22-2008, 03:36 PM   #2 (permalink)
aeneas's Avatar
Club Region: Southeast
Reputation: aeneas is an unknown
im not really an expert but that belt sounds like it could be it. maybe its not the right one and the alternator is not getting turned very well.
Old 08-22-2008, 11:11 PM   #3 (permalink)
Reputation: Khooper is an unknown
sounds like a bad battery , altough you had it check it is very possible that it has lost the ability to hold a charge , you get it tested when the charge is high it will pass the check test , but under a constant load the battery drains ........other possibilities is the battery cables are worn or corroded this will cause the battery to drain but not recharge , clean the battery cables at they spot where the mount to the battery terminals ....
Autopartswarehouse Addict.
Drive Safely and Move Freely.
Old 08-23-2008, 10:54 AM   #4 (permalink)
Need to check both ends of the battery cables.Do a load test on the battery and buy a multimeter.
Aarg matey!
ECU Pirated by RomRaider
Old 08-26-2008, 11:45 PM   #5 (permalink)
both end like the postive and negative? or where the cables starts and ends?
Old 08-27-2008, 06:14 PM   #6 (permalink)
oh yeah another thing, right before all this situtation happen i had a check light engine light...it was P0171 - system too lean (bank 1)..i did some research on it and it said something fuel being too lean or dirty MAF (Mass Air Flow). could this be a cause of the problem too?
Old 08-27-2008, 06:53 PM   #7 (permalink)
Yes and yes.
Aarg matey!
Old 08-27-2008, 07:40 PM   #8 (permalink)
SuBeast's Avatar
Club Region: NorCal
Reputation: SuBeast is on thin ice
it drains WHILE driving? That would sound like a Alternator problem... Like, it's not charging while driving... WtF? Autozone don't know Shiat....
Jetta VR - GIAC Powered
FAST
RELIABLE
CHEAP
Pick 2
