Electical and vacuum help please. - Page 3 - Subaru WRX Forum
 2Likes
post #31 of 41 Old 10-07-2013, 09:31 AM
boo-key's Avatar
Does yours have 2 connections for hoses on the throttle body? If it does they are for coolant. That is another possibility for the hose in pic 4.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #32 of 41 Old 10-08-2013, 02:44 PM Thread Starter
STravis is an unknown
Both of the coolant lines are hooked up to the throttle body. The hose in pic 4 has about the same diameter as a nickel.
STravis is offline
post #33 of 41 Old 10-08-2013, 02:46 PM Thread Starter
Originally Posted by STravis View Post
http://www.wrxtuners.com/forums/memb...re953-sub5.jpg
What is this wire. It is spliced into a wire loom on the passenger side frame rail.
After looking around, I believe this is the wire to the security horn.
STravis is offline
post #34 of 41 Old 10-09-2013, 01:46 PM Thread Starter
So I have been trying to get injector pulse and am not having much luck. I have used an ohm meter and the injectors have power all the way through the harness but it isn't getting ground. I found where the injector ground wire goes from the ecu to where it grounds on the body and the ohm meter reads that it has interference. I spliced in a wire from the harness directly to the body ground and now the #1 injector has a pulse but the other 3 injectors do not. Any ideas?
STravis is offline
post #35 of 41 Old 10-09-2013, 10:16 PM Thread Starter
Does anybody have pictures of how the pcv hoses are routed and where they go?
STravis is offline
post #36 of 41 Old 10-09-2013, 10:24 PM
boo-key's Avatar
There is a diagram in the perrin turbo inlet install instructions that I linked earlier in this thread. Thats why I put it in there for ya
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #37 of 41 Old 10-09-2013, 10:27 PM Thread Starter
I went through that and couldn't figure it out. I dont think the hose on the actual pcv valve is the right hose.
STravis is offline
post #38 of 41 Old 10-13-2013, 11:10 AM Thread Starter
Does anybody know where I can get a socket for the front marker light/turn signal?
STravis is offline
post #39 of 41 Old 10-13-2013, 05:47 PM
boo-key's Avatar
You can probably get one from someone parting out a car on nasioc .
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #40 of 41 Old 10-13-2013, 08:11 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
Pmp auto sales in pa will have them.
Sent from AutoGuide.com App
06_hawk_eye is offline
post #41 of 41 Old 12-07-2013, 02:52 PM Thread Starter
So its been a while since I've been on here, I have the engine bay all straightened up and almost everything is back where it should be. The only wire I can't figure out is on the passenger side of the engine bay. It a a red wire with a yellow stripe and it is part of the harness that comes through the firewall on the passenger side of the engine. Does anybody have any idea what it is?
STravis is offline
