Electical and vacuum help please. - Page 2 - Subaru WRX Forum
 2Likes
post #16 of 41 Old 10-03-2013, 08:50 PM Thread Starter
STravis is an unknown
Originally Posted by BLAZE2099 View Post
You bought a nightmare.
I'll shout out to some of the more experienced guys on here and see if they can come chime in.
Good luck..... Btw, your belts off
Yeah it is kind of a nightmare, but I got it for a really good deal.. I'm in the process of taking the front of the motor apart to check the timing to see if that's why I'm not getting an injector pulse. It's gonna be a slow build but hopefully I'll get it running.
STravis is offline
post #17 of 41 Old 10-03-2013, 08:52 PM
boo-key's Avatar
Originally Posted by STravis View Post
I'm new to turbo motors and I'm not sure on some of the terms like "tgv" and some of the parts that go along with it but I'm trying to learn. It does have a ewg though and it has a manual boost controller.
Tgv's are between the intake manifold and head. They have little motors/sensors on each side with electrical plugs. In the first pic to the left of the dipstick under the intake manifold is a connector on one. What brand boost controller? I agree with randy that you bought a mess. If your not familiar you may be in over your head but, we will help you as best we can.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #18 of 41 Old 10-03-2013, 09:33 PM Thread Starter
It's a hallman boost controller and a tial wastegate. I've done cam swaps on ls motors so I'm mechanically inclined but new to turbos. Thanks for all your help so far
STravis is offline
post #19 of 41 Old 10-03-2013, 09:40 PM
Brockton's Avatar
We're neighbors hah, I'm in el paso. If your in the area, the subaru tech that works at the subaru dealership. He's done a lot of performance builds on the EJ's around here. His name is Brian Small, might want to look him up sometime.
Brockton is offline
post #20 of 41 Old 10-03-2013, 09:51 PM
boo-key's Avatar
boo-key is offline
post #21 of 41 Old 10-04-2013, 08:30 AM
wrxdan's Avatar
wrxdan is more helpful than not
pic #2 looks like your window washer fluid plug
wrxdan is offline
post #22 of 41 Old 10-04-2013, 10:20 AM
Pic #4 looks like it might be one of the breather hoses that connects one side of the engine to the other. On a stock car it connects to a long sideways "Y" shaped black metal pipe mounted on the top/front of the top mount intercooler (See my stock pic). Many people cut or re-route them for air oil separators or catch cans. Any chance you could get a short video of the area showing multiple angles?
post #23 of 41 Old 10-04-2013, 03:10 PM Thread Starter
I don't have a top mount intercooler and I'm not sure where that "Y" is. Do you know where to re-route it to? Does it tie into the valve cover breathers? And I don't have a way to post a video, but I can e-mail one.
STravis is offline
post #24 of 41 Old 10-04-2013, 08:02 PM
Anybody near you with an 02-07 wrx?
You need them to park next to you for a few hours.
This is by far one of the worst used engine bays I've ever seen.
Hope you didn't spend much over three grand for it man
post #25 of 41 Old 10-04-2013, 08:33 PM
boo-key's Avatar
pic 4 kinda looks like the hose that would connect to the stock bov. Which side of the engine bay that hose on? Does it come up beside the throttle body? My engine looked similar when I had my intake manifold, tgv's, and intercooler off. At one point I thought I was in over my head but, Was just patient and tyler sent me some pics of his and it went back without a snag. I know its a different story though when you didnt take it apart. I agree with Randy. Find another wrx for refrence. Even if you gotta pay a stranger!
BLAZE2099 likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #26 of 41 Old 10-05-2013, 12:56 AM
Hmm, do you mean you don't know where the "Y" is on your car or you can't find it on the pic I posted? You don't really need it anyway - you can make your own "T" connection. There should be a nipple (I believe you're right, they are technically called the valve cover breathers) on the left side of the engine near the top around the middle and another one on the right side near the top around the middle. You want to connect those two together with a length of heater hose with the same inner diameter as your stubby disconnected one. Somewhere along that, you want to run a "T" connection and connect that third line to the nipple on the intake turbo inlet tube that runs under the intake manifold. It's hard to explain, but if I was there, I could show you exactly what I'm talking about. I'm not even sure we've correctly identified the hose...
post #27 of 41 Old 10-05-2013, 03:57 PM Thread Starter
I've been looking everywhere for somebody with a wrx I could compare it to. I think I would be able to figure it out if I did that. And it looks worse in the pictures than it really is. I took some stuff out to get that deep into the motor.
STravis is offline
post #28 of 41 Old 10-05-2013, 04:01 PM Thread Starter
The hose in pic 4 comes up out of a "T" that comes out of the block. The other line on the "T" goes to the perrin intake before the turbo.
STravis is offline
post #29 of 41 Old 10-06-2013, 04:24 PM
Sounds like your unconnected open end just needs to connect to a nipple on the opposite side of the block. You could probably just run a straight line all the way across.
post #30 of 41 Old 10-06-2013, 07:11 PM
boo-key's Avatar
Went out and looked at mine. I see that hose and the tee but can't tell where it goes without taking my top mount intercooler off.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
