ecu harness - Subaru WRX Forum
post #1 of 8 Old 02-06-2004, 07:55 PM Thread Starter
intec is an unknown
ecu harness
i was installing a turbo timer and when i spliced the wire from the ecu harness i cut it too short. is there any way to replace one of the wires in the harness or do i have to buy a new harness. by the way i have a 2002 wrx
intec is offline
post #2 of 8 Old 02-07-2004, 08:09 AM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
just get the same gauge (standed) and solder it on at both end and put some shrink heat wrap on it.
Regards,
-kobi
Kobiyashi is offline
post #3 of 8 Old 02-07-2004, 10:57 AM Thread Starter
intec is an unknown
could you give me an idea on how to do that?
intec is offline
post #4 of 8 Old 02-07-2004, 01:36 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
Get a wire thats the same size as the one you cut, should be a 16 gauge if I am thinking about the right one. Then open the harness so you have more room to work on it. To open the harness, look on the side you should see little ears that keep it closed, push down on them or bend the plastic keeping them in up, and it should open up. Make sure not to break anything. Get a small piece of shrink heat wrap from Home Depot or Radio, and slide is onto the stock wire. Then tin the wires in the places where you are going to solder them, so they will stick together. Then touch the wires together so they stick. Make sure to keep your hands nice and steady. Once they are together, slide the shrink heat wrap on top on exposed areas of the wire, and squeeze onto the wires. Then use a heat gun, or a hair dryer, or a paint peeler, etc, and expose it to the wrap all around; just some quick exposer, NOT TOO LONG. Then if you want you can test its impedency, in order to make sure its getting a signal and not getting distorted. If everything checks out then you are good to go.
Che
Tut4u2 is offline
post #5 of 8 Old 02-07-2004, 05:33 PM
fc735's Avatar
ok...lets clarify this before you start soldering or cutting....
WHICH wire did you cut, and which wire are you talking about?
are you talking about the larger gauge (12-10) that are for the Ign switch, or were you hooking into the O2 sensor wire?
and if you dont know how to solder, learning how to do it on an ECU harness is not the time to.....
and i disagree with some of your methods Tut.....but hey, what do i know?
fc735 is offline
post #6 of 8 Old 02-07-2004, 06:18 PM
Tut4u2's Avatar
Images: 11
Joey, I would take your word over mine any day when it comes to fixing cars, lol. You are the mechanic around here.
Che
Tut4u2 is offline
post #7 of 8 Old 02-07-2004, 07:58 PM
fc735's Avatar
TECHNICIAN!!!!
fc735 is offline
post #8 of 8 Old 02-07-2004, 10:58 PM
Tut4u2's Avatar
Images: 11
Aight aight, I got a compromise. You are the man around here.
O and I meant sauter not solder for some of that stuff on my post, you can see which ones.
Che
Tut4u2 is offline
