DTC p0018...Crankshaft/camshaft correlation - Subaru WRX Forum
post #1 of 11 Old 04-13-2011, 08:44 AM Thread Starter
wiechWRX's Avatar
wiechWRX is an unknown
So I got this code about 2 weeks ago. There was no change in the car it still runs perfectly fine, I thought it was a fluke so i cleared the code and about 30-40 miles later it came back on. I took the crank sensor out and there was no debris on it so I took the timing belt covers off and my timing was still perfect. Any other ides of what this could be? My car is getting tuned in 2 weeks and I'd like to have this fixed! Any help would be appreciated. Thanks!
Steven Wiech
wiechWRX is offline
post #2 of 11 Old 04-13-2011, 08:59 AM
the only two times I've seen this code pop up it turned out the cam position sensor was bad even though it still looked ok
post #3 of 11 Old 04-13-2011, 09:27 AM Thread Starter
wiechWRX's Avatar
Alright I was thinking about replacing it anyways so i guess that'll be my next step lol thanks!
Steven Wiech
wiechWRX is offline
post #4 of 11 Old 04-13-2011, 05:55 PM
Who is doing your tune?
post #5 of 11 Old 04-15-2011, 09:43 AM Thread Starter
wiechWRX's Avatar
JS Dyno and I figured it out on the driver side valve cover i pulled the banjo bolt out and there was some shavings on the solenoid. I drove it for 100 miles after cleaning it out, checked it again and it's all good!
Steven Wiech
wiechWRX is offline
post #6 of 11 Old 04-15-2011, 07:27 PM
Nice find. Good luck with your tune.
post #7 of 11 Old 04-18-2011, 10:17 AM Thread Starter
wiechWRX's Avatar
Thanks it came out pretty good. 330whp on 17psi. Im taking it bakc this week for a high boost map. Theyre shooting for around 22 to 24 psi.
Steven Wiech
wiechWRX is offline
post #8 of 11 Old 04-18-2011, 02:15 PM
Good numbers man! especially if your still on a DomI
post #9 of 11 Old 04-18-2011, 09:10 PM
His set-up is strikingly simular to a extent. Except he is running a FMIC and grimmspeed headers. I'm TMIC and GT Spec headers. The turbos are pretty close to each other. Beyond the fact that he got his turbo compressor housing PnP'd. Let us know the final numbers man. I love my new tune 350 whp and 375 wtq at 23 psi. I hope your pistons last with all the power you are putting down.
post #10 of 11 Old 04-19-2011, 09:45 AM Thread Starter
wiechWRX's Avatar
I got wiseco forged pistons, arp head studs and cometic head gaskets to so hopefully she lasts! haha thanks guys
Steven Wiech
wiechWRX is offline
post #11 of 11 Old 04-19-2011, 07:10 PM
Opps, I missed that part. You should be in good shape then. Let us know how it turns off.
