downpipe = cel p0420 - Subaru WRX Forum
post #1 of 9 Old 08-30-2007, 09:45 PM Thread Starter
achavez is an unknown
ok ive done the research just want a confirmation on my findings. i intsalled my downpipe 2 weeks ago and i just barely got a cel (p0420). so after research i learned i need a cel fix or i can just drive the car with the cel on right.? my car isnt in limp mode right? thanks for any feedback
achavez is offline
post #2 of 9 Old 08-31-2007, 12:48 AM
bigbadbuddha's Avatar
Images: 15
I would go out and get the cel fix or better yet some form of EM.... You aren't gonna kill your car but it is always good to do things right
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #3 of 9 Old 08-31-2007, 12:54 AM Thread Starter
i forgot to mention i used an xpt map to reflash my ecu.
achavez is offline
post #4 of 9 Old 02-28-2008, 01:07 PM
ColoWRXer's Avatar
ColoWRXer is more helpful than not
a fix is good, an AP is better. it specifically eliminates that code (as well as others) that are caused by tbe. i had my tbe on without EM for probably 12K before the cel went off, then everytime i cleared it it would come back within 50 miles. the AP fixed that and more.
ColoWRXer is offline
post #5 of 9 Old 02-28-2008, 01:10 PM
octoparrot is an unknown
Send a message via AIM to octoparrot
True, but you can do the same with Enginuity / Opensource
OCTOPARROT
octoparrot is offline
post #6 of 9 Old 08-30-2008, 01:50 PM
bluesubiaz's Avatar
bluesubiaz is an unknown
i put a catlees down pipe on my car and got the same code it a bad o2 sensor so get a new but before you do go on ebay and get a o2 sensor extenstion it pulls the sensor back so the sensor dosent pick up the bad gasses but still gets a reading i did this on my car and im now check engine light free, and the rear o2 sensor is relativly inexpensive un like the front
bluesubiaz is offline
post #7 of 9 Old 09-20-2008, 11:19 PM
2006wrxturbo's Avatar
2006wrxturbo is an unknown
a P0420 code is a catalyst inefficiency code, not a bad o2 sensor.
2006wrxturbo is offline
post #8 of 9 Old 09-22-2008, 03:02 AM
sfelix818 is more helpful than not
But running a catless 06+ wrx without a good tune or map= Boost creep.
sfelix818 is offline
post #9 of 9 Old 09-22-2008, 01:20 PM
Boost creep can not be tuned out. Only lessened. You either need to change the pill size or get a 3 port BCS to fix the problem. Its a mechanical issue. Just make sure you have it set up correctly and protuned for if you go the BCS route. Changing the pill will not require a protune.
Check out these links:
CobbTuning.com - Service Bulletin: 07 WRX/STi Overboosting with Catless Exhaust
CobbTuning.com - How Subaruís Factory Boost Control System Works
