This doesnt sound good...... Mechanic advice? - Page 2 - Subaru WRX Forum
post #16 of 23 Old 02-14-2013, 05:12 AM
If you can't feel it in the clutch then it's probably not rod knock.... but then again it sounds like it is since it increases with RPM....
post #17 of 23 Old 02-14-2013, 07:39 AM
I've never felt rod knock thru the clutch.
post #18 of 23 Old 02-14-2013, 09:30 AM
Strange.... I did in my DSM and I've felt it in a couple Speeds.
Maybe because of motor/tranny mounts on my cars...
post #19 of 23 Old 02-14-2013, 05:01 PM
rex2002's Avatar
Maybe valve tap then that is excessively loud for valves tap. The triangle part really wasn't even spinning in your video either. So, you might be onto something there. You might just need the timing belts, all your pulleys changed, and possibly your valve lash reset. I know that wagon racer used to say that after so many miles the valve lash needs re-done or it can get a bit noisey under the hood/hurt the engine from the lash being so off.
the triangle part is the ac compressor,if his ac is not on it will not spin.
rex2002 is offline
post #20 of 23 Old 02-14-2013, 05:10 PM
rex2002's Avatar
Originally Posted by brfatal View Post
Sounds like rod knock to me.
This was my last engine before it was torn down.
https://www.youtube.com/watch?v=OeyJLvm3Zk8
Is the sound RPM dependent? Does it change when you rev?
yes the noise does get faster and a little bit louder when she is under higher rpm. looking at your video was that shot from a dead cold start? i always thought if you had rod knock it would always be there (the sound of knock) at all times. in my case it takes 10 mins then the noise is there. im holding boost fine and not losing or burning oil. a few of my buddys with high hp stis said that it still could be rod knock b/c once it warms up the oil is heated up(same concept if u try to shift your car on a real cold day,it gets better when its warmed up).im throwing no codes and everything that we can check out via the cobb ap turns out fine. being that this is clearly a mechanical issue its hard to find out whats wrong b/c there are no codes that would be throw on this type of issue.
any thoughts ?
rex2002 is offline
post #21 of 23 Old 02-14-2013, 10:43 PM
any thoughts ?
Yes, mine was a cold start, however in my case I was only experiencing rod knock on cold starts until oil pressure built up. It started as barely audible but quickly got incredibly loud.
My suggestion is to start watching Youtube videos with piston slap, rod knock, spun bearings, etc and see if any of those sound similar to yours.
post #22 of 23 Old 04-17-2013, 07:38 PM Thread Starter
AllExtinct's Avatar
Update:
After changing my plugs the knocking noise went away. The plug the was closest to the knocking noise was the one in the worst shape.
I did a temp fix on the whining noise, just disconnected the belt off of the ac compressor.
After removing the ac belt tentionor bracket I noticed the bearings in the tentionor are shot so gonna go for the simple fix by replacing this before replacing the compressor unit.
Besides for that she purrs like a kitten again.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #23 of 23 Old 04-17-2013, 07:41 PM
Great to hear chuck, maybe you can make the meet this year if we do one
