i have the same exact noise,check out my vid. i cant seem the figure out the issue either, my tuner said it could be "rod knock" or piston slap,but its strange bc i never race or drive her hard. hopefully someone else can chime in on here and help out,b/c im at the point to drop in a sti block but if its a simple fix i would rather fix than swap
in my case no, it only happened shortly after we hooked her up to a smoke test to check for boost leaks,found leaks and fixed them but weeks after we did the job the noise came.
i cant feel anything in the clutch. i am due for a timing belt change. my car has about 156k miles on her.my noise is only coming from the head area closest to the front of the car,near the battery. ive been running stage two cobb street tune for over a year with no problems,but now im running into this. i just recently did an oil change and swapped a court with Lucas to hope that would fix the problem but no luck
I have around 132K on it. As soon as I get my income tax back Im gonna have my mechanic do my timing belt/water pump.
I dont feel anything in the clutch.
Gonna check around the net some and see if anyone has a similar problem. The whining noise is getting on my nerves.
Chuck: Yours sounds more like something is clunking inside the turbo its self (dead turbo) or heads. Not a deep RPM clunk. The whining has me stumped. Is your performance hindered? Even when not pushing it?
Rex2002: Yours sounds like you have a rod bearing going. Odd that its taking a while for it show up. But, it sounds like your short block is not going to last. Piston slap doesn't normally happen when warmed up unless you have some shit forged pistons. That being the case you'd have piston slap all the time and it would get less noisy when warmed up. I've had some rough CP pistons once and man does piston slap really get annoying until you're warmed up.
No performance issues that I can tell. The whining might be the pulley bearings going in the refridge unit, from what I've read online the triangle part in the middle of the pulley should spin freely when the engine is off and I tried mine and it spins a bit and then seems to catch and spin again. The knock is faint when the hood is down, I Cant hear it knock when I'm driving.
Maybe valve tap then that is excessively loud for valves tap. The triangle part really wasn't even spinning in your video either. So, you might be onto something there. You might just need the timing belts, all your pulleys changed, and possibly your valve lash reset. I know that wagon racer used to say that after so many miles the valve lash needs re-done or it can get a bit noisey under the hood/hurt the engine from the lash being so off.
