Diff Problems? - Subaru WRX Forum
post #1 of 9 Old 12-12-2010, 04:10 PM Thread Starter
mfarnham's Avatar
mfarnham is an unknown
Diff Problems?
When its cold outside, and I am taking off from a stop, I occasionally here a squealing noise like one of my rear tires is spinning. It used to go away once the car drove for awhile, but now that its cold all the time it doesn't seem to go away. Would this be a problem with my rear diff? I don't know if it actually is a tire spinning or something else squealing.
mfarnham is offline
post #2 of 9 Old 12-20-2010, 06:13 PM Thread Starter
mfarnham's Avatar
No one?
mfarnham is offline
post #3 of 9 Old 12-20-2010, 09:09 PM
Hondafan's Avatar
Tell me more about the sound. . . Is it coming from both sides? Is it just a rubber-y squealing sound? Metal scraping on something sound? Or is it like maybe the bushing on the top of the strut tower is squeaking? Can you mimic it with swerving? Or is it only from a dead stop? I would check around the hub area first to see if there's anything rubbing like at the CV axle boots. I don't know what else to say without a little more detail. Let us all know.
Hondafan is offline
post #4 of 9 Old 12-20-2010, 11:36 PM
wagonracer's Avatar
Missed this post the first time. That's an odd one, when you take off normally the front tires are doing most of the work and I've never had tire squeal from my car unless I was really trying to ! Please give us some more details or record it somehow (vid maybe)
wagonracer is offline
post #5 of 9 Old 12-21-2010, 09:51 PM Thread Starter
mfarnham's Avatar
It sounds exactly like a burnout (wheel squealing on pavement). I only hear it when taking off from a dead stop. It sounds like its coming from the rear. And if I ride the clutch I can draw out the sound for longer.
I don't appear to have any uneven tire wear so I'm assuming it isn't actually a wheel spinning.
mfarnham is offline
post #6 of 9 Old 12-22-2010, 06:51 AM
Anything leaking ? Have you taken the wheel off and gotten under there to look around ?
post #7 of 9 Old 12-22-2010, 01:26 PM Thread Starter
mfarnham's Avatar
I don't think anything is leaking. I just had my car checked out and they replaced my front axle boots. They didn't say anything about the rear end.
mfarnham is offline
post #8 of 9 Old 12-23-2010, 06:32 AM
Are you saying they JUST replaced the boots then this started to happen? Or they replaced the boots after you started hearing the sounds ?
post #9 of 9 Old 12-23-2010, 08:19 PM Thread Starter
mfarnham's Avatar
Neither... I think the sound is coming from the rear. And I'm saying that my front axle boots were just replaced, and they didn't notice any problems with my rear end.
mfarnham is offline
