Cylinder 3 misfire. and a rough idle. - Subaru WRX Forum
post #1 of 10 Old 09-22-2010, 12:34 AM Thread Starter
bdon21's Avatar
bdon21 is an unknown
Question Cylinder 3 misfire. and a rough idle.
i have a 2006 wrx tr. check engine light brought up a code saying cylinder 3 misfire. i got new plugs, and switched coilpacks and it continues to give me a cylinder 3 misfire code. weve also done a compression test on cylinder 1 and 3. it was were it shuld be. ive noticed at idle itll sit about 900, but when i giv it gas and rev it up a bit then let it fall back down. the tack falls to 0-100 rpm, and slowly comes back to 900rpm, or kills. how do i solve these problem?
bdon21 is offline
post #2 of 10 Old 09-22-2010, 01:13 PM
What other mods do you have done to the car?
post #3 of 10 Old 09-22-2010, 08:25 PM Thread Starter
bdon21's Avatar
apg turbo back 3 1/2 in exhaust
forced performance 20g turbo
cobb intake
720cc injecs
xs fmic
tal bov
perrin pulleys
thts about it. ive tried every diognostics test. and cant find anything. im thinking tune but not sure.
bdon21 is offline
post #4 of 10 Old 09-22-2010, 09:08 PM
do you have a lightened flywheel...and did you check the gaps on your plugs...you might also have a failing fuel injector
post #5 of 10 Old 09-23-2010, 07:38 AM
^ In addition to Matt's response, Who knows... might be something as simple as cleaning the MAF.... or a coilpack takin a dump.
post #6 of 10 Old 09-23-2010, 06:41 PM Thread Starter
bdon21's Avatar
Ive checked all those things. got new plugs. which are iridiums so non gapable, and also swapped the coilpacks and i still continue to get the misfire code on cylinder 3.
bdon21 is offline
post #7 of 10 Old 09-23-2010, 11:57 PM
try moving injectors around
post #8 of 10 Old 09-24-2010, 07:34 AM
I recently saw a jacked up (bent) fuel rail on an 02 and 03... have you messed with the intake manifold any ?
post #9 of 10 Old 09-26-2010, 09:19 PM Thread Starter
bdon21's Avatar
ok. think we may hav figured it out. the ruf idle is explained. i recently disconected my battery todo wrk on her. and i guess the car had to relearn some tuning ### it dnt do it anymore,,, and my misfire codes appear tobe becuz of faulty injector wiring.
bdon21 is offline
post #10 of 10 Old 09-26-2010, 09:39 PM
I figured it was a fuel injector related issue of some kind
