cutting out when accelerating - Subaru WRX Forum
post #1 of 9 Old 03-01-2012, 09:27 PM Thread Starter
subaruwrx16 is an unknown
i have a 2002 wrx that is all stock except for it is straight piped, but i am planning on gettin a new exhaust soon. so my car runs great with no problems if i am just cruising, but a problem recently came about. When i put the pedal to the floor to do a pull it feels as if i am hitting a governer at about 4500 rps for just a split second, the car cuts out and sort of jerks real fast then it will go back to normal, this happens in 3rd, 4th, and 5th gear... does anybody know what the problem could be and how i can fix it?? any advice would be greatly appreciated !
Thanks, Daymon
subaruwrx16 is offline
post #2 of 9 Old 03-01-2012, 09:42 PM
bad grocerygetter's Avatar
Is the down pipe stock? If not then there's your problem...it needs a tune on it with that part. Is it throwing a cel? If it is get that code read and let us know what it is. How long has it been doing that?
Kevin.
bad grocerygetter is offline
post #3 of 9 Old 03-02-2012, 05:48 AM
Fuel cut possibly.
post #4 of 9 Old 03-02-2012, 08:34 AM
Can you reach 4500RPM without flooring it? If you can, and then floor it, does the cut out happen? If yes to both of those, you may have a boost leak somewhere. Check the piping and make sure all your clamps are on tight.
post #5 of 9 Old 03-05-2012, 08:59 PM Thread Starter
my downpipe is stock, and it isnt bringing up any CELs. i will try to accelerate slowly and see what happens. i will let you know what i find!! thanks guys
post #6 of 9 Old 03-11-2012, 09:46 PM
ejs0806 is more helpful than not
check all your houses connected to the turbo and boost control solenoid thing.. Under the little black cover on passanger side near the strut mount. My hoses where cracked and letting turbo go crazy with some boost and im assuming not enough fuel but i had same symptoms it was fine and normal until i put my foot into it
ejs0806 is offline
post #7 of 9 Old 03-19-2012, 09:13 PM
boomerwrx is an unknown
im glad i stumbled upon this thread because my car is doing the same thing
boomerwrx is offline
post #8 of 9 Old 03-20-2012, 01:13 PM
Chris-pee's Avatar
Chris-pee is an unknown
Mine did that for a little while on cold days. After I flashed it with the accessport I noticed it stopped. It would only do it when it was cold out (50 degrees or so and colder) and the engine was cold.
Chris-pee is offline
post #9 of 9 Old 06-05-2012, 08:37 PM Thread Starter
fixed the problem, having a straight pipe with no cats and a stock downpipe is a bad idea i found out!! the stock downpipes have cats so it restricks the air flow, once the flow was hitting the catless pipe which is not restricted at all it would suck to much air causing it to cutt out. i ended up buying the cobb stage two powerpack and it fixed the problem, the bigger downpipe and the exhaust has the same air restriction and it doesnt cut out anymore!!
