Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 07-28-2009, 03:09 PM   #1 (permalink)
Car: 09 WRX
Reputation: ST1NG469 is an unknown
crunch on startup 09wrx
I have a 2009 wrx sedan. heres what happens. i start my car, shift into first gear, and then as im dropping my clutch i there is a loud crunch. This only happens when i start my car and shift into first gear. it sounds like its coming from the front driver side but sometimes it sounds like the front passenger side. I can also feel the vibration in the pedal. When the crunch happens the car stutters slightly. When i let the car idle for a while before i go the sound isnt as loud but is still there in the same fashion. The only time this happens is the first time i shift into first gear after i start my car.
Any ideas other than bringing it into the shop and getting it fixed cause i did that and they spent a few hours looking at it and couldnt find the problem. I even drove around with the guy and pinpointed the noise and he still coundnt find it.
Old 07-28-2009, 06:12 PM   #2 (permalink)
Car: 09 WRX
Reputation: booosted09 is more helpful than not
is the crunch like a can crunching? i'm just not sure what kind of sound it is.. and you said it will only do it once when you first start the car?
Old 08-19-2009, 10:22 AM   #3 (permalink)
Car: 09 WRX
crunch
yeah but heavier. for a while i thought i was kicking up some rocks when i started but then it started happening everywhere and every time. sounds like a half shift almost but still heavier and harder if that makes sense.????
Old 08-19-2009, 06:29 PM   #4 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is known to be trustworthy and helpful 03 CrazyTaxi is known to be trustworthy and helpful
Since it's an 09, TAKE IT TO THE DEALER.
Old 08-19-2009, 11:01 PM   #5 (permalink)
I vote for what crazytaxi said. If theres a problem should still be covered under warranty.
