Cooling problem after timing belt install - Page 2 - Subaru WRX Forum
post #16 of 18 Old 02-28-2009, 11:59 PM
dubrex2002's Avatar
Send a message via AIM to dubrex2002
another easy way to tell if the water pump is working is take the cap off, and rev it and you can watch the water/coolant move down when you gain rpm's and when you let off it will come back up (sometimes it will overflow a little bit)
-sounds like a boat-
dubrex2002 is offline
post #17 of 18 Old 03-02-2009, 06:04 PM Thread Starter
Wasp642's Avatar
i put the one in with the 1/8" hole in the top, it cools fine when up to 205*, cools right down, but takes forever to get to operating temperature and the oil is to cold. Also, when run hard, the temp. gets down to 145* lol, im gonna try a very small hole in one and try that out... This is a real crapshoot as i know my waterpump in fact does pump water, its just the Tstat that sticks. One i had in there really stuck, had to keep it in 4th gear at 60 mph to keep the rpms up to stay at 201* !!!!! That was a nervous ride home from work.
It has to be air in there somewhere grrrrr.
-02 WRX Blouch 18G'd Juggernaut of Beastliness.
Wasp642 is offline
post #18 of 18 Old 01-17-2010, 06:44 PM
Sounds to me as if the water pump has a differnt impeller not moving enough coolant when going down the road OR you have a head gasket issue that shows up under stress.
busadave is offline
