Compression & Spark, NO start~help - Subaru WRX Forum
post #1 of 2 Old 01-26-2011, 10:41 AM Thread Starter
From the beginging:
Car had bent valve so I have a had a valve job done and pretty much everything replaced i.e. spark plugs timing belt, cam gears (fiber ones), ect
I am not working on the car myself but the mechanic has ran into an issue-
Everything has been put back togther and the car has compression and spark but she wont turn over---we double check the gear marks to make sure everything is lined up and there is no teeth missing on the gears and there is a full tank of gas---
Just need some ideas of other stuff for him to check, Subaru has told him she should be running like brand new
THANKS
flsubygrl is offline
post #2 of 2 Old 01-26-2011, 03:23 PM
Won't turn over as in it won't even crank or it cranks but won't start?
