code p0244 on 18g argggg!!! - Subaru WRX Forum
post #1 of 13 Old 09-16-2006, 09:22 PM Thread Starter
wrxcop's Avatar
wrxcop is an unknown
2006 tr deadbolt td06-18g all supporting mods, cobb ap, catless turbo back, water sprayer. Well just got into my car after the break in and I was running 18.3 psi of boost on two consecutive runs, 3rd gear, 60mph-80mph or so, no problem 3rd run i give it a 5 second spray and wot 60-80 and I feel like i hit a brick wall, check engine light comes on and I about pee my pants. The temprature is about 65 degrees and im not to high above sea level. I know this error code deals with boost creep etc, but can my water sprayer really be so effective to push my car over the limit that the wastegate can hold and how bad could I have messed up my engine? Be nice to my noobness, any suggestions greatly appreciated.
wrxcop is offline
post #2 of 13 Old 09-16-2006, 11:29 PM
trek98xc's Avatar
trek98xc is an unknown
Send a message via AIM to trek98xc
Spray? If you are talking about spraying (nitrous) I would say you need a protune for that my friend.
rob
▼SbiΣ Mi▼
trek98xc is offline
post #3 of 13 Old 09-17-2006, 05:24 AM Thread Starter
wrxcop's Avatar
no an intercooler water sprayer?
wrxcop is offline
post #4 of 13 Old 09-17-2006, 08:08 AM
mxboy15u's Avatar
mxboy15u is an unknown
Sounds like your car pulled timing. Is this car tuned? If not it needs to be.
mxboy15u is offline
post #5 of 13 Old 09-19-2006, 09:21 PM
joker97's Avatar
joker97 is an unknown
does the car work normally otherwise?
joker97 is offline
post #6 of 13 Old 09-30-2006, 06:48 AM
trktwrx is an unknown
Send a message via AIM to trktwrx
Sounds like fuel cut to me. You just leaned out at that amount of boost. I would try messing with your tuning. Definitely fuel cut though.
trktwrx is offline
post #7 of 13 Old 09-30-2006, 02:30 PM
9d2TSi's Avatar
I doubt it's fuel cut if he has all of the supporting mods for that turbo, I'd say that he probably has too much fuel. When you hit your fuel cut, especially at the rpms and boost level that he's talking about, it would be like hitting a brick wall, not a little bit of hesitation and a cel.
P0244 - Wastegate control solenoid valve malfunction (high input)
My suggestion, get a better form of boost control.
9d2TSi is offline
post #8 of 13 Old 10-04-2006, 05:19 AM Thread Starter
wrxcop's Avatar
I have 560 injectors, after more investigation I'm only seing 18.6 psi. I hit 18.6 and hold it in third gear for a few seconds. Cobbs off the shelf 18g map is only set for 17.5 (+-.7 psi), and the map is pulling me back becuase its substained boost and its out of map parematers. Is it ok to run this amount of boost on 560 injectors? Can I just open my aP map up to allow for this, or what?
wrxcop is offline
post #9 of 13 Old 10-04-2006, 08:10 AM
bigbadbuddha's Avatar
Images: 15
If it felt like you hit a brick wall, then it was definitely fuel cut...
ANy other problems with your car since???
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #10 of 13 Old 10-04-2006, 06:48 PM Thread Starter
wrxcop's Avatar
No other than the fact that I have to feather the gas at wot throttle for just a sec in third gear so i don't substail the 18.4 psi
wrxcop is offline
post #11 of 13 Old 10-04-2006, 06:51 PM
awd>fwd's Avatar
awd>fwd is an unknown
Yep, I've had that one. How long have you been on the 18g map? I did that 3x in the first week of stage 2 cobb. You may get past it.
Brent
awd>fwd is offline
post #12 of 13 Old 10-04-2006, 08:51 PM Thread Starter
wrxcop's Avatar
i switched to the 91 18g map using 93 gas so hopefully it will be safer.. but my car is getting a protune the 27th so it till all get worked out then
wrxcop is offline
post #13 of 13 Old 10-04-2006, 10:25 PM
awd>fwd's Avatar
Well, you weren't supposed to use the deadbolt 18g on that map really, you were supposed to use a Forced Performance turbo, they are a little different.
Brent
awd>fwd is offline
